built the all wood flatbed
Several people have inquired about a wood flatbed, well i built one on Saturday, and i thought people might be interested in it - I am 26 years old and i built it completely by myself in one day at a cost of about $150 i have more plans that will cost more money but that is the price so far
part list: 5, 8' 4x4's 13, 8' 2x6's 2, 8' 2x4's 2 12" carriage bolts 4 8" carriage bolts 4 10" carriage bolts 1 box of 3.5" 10 year desk screws pic: ![]()
1967 K20 'the white truck' sm420/Rockwell t221 Dana 44 front w/ Dana Spicer 1/4 turn lockouts Eaton Ho52 rear "holy **** this thing is a tank!" As soon as your born you start dying so you might as well have a good time! |
Re: built the all wood flatbed
Looks really good, a headache rack would compliment it well.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
Factory Strippers Rule!
![]() Join Date: Mar 2009
Nice! Now add some tie down points, and go hauling!
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
i was thinking about a roll-bar with a closed front so i would have a "box" when i added some sides
You should do a write up.....or take a bunch of close-up pics of the completed project those of us that want to do this.
I think this is the route I may go due to the bed on mine being trashed....too many years as a farm truck! Thanks Thad
1968 C10 CST LWB 2x4 Engine: 1975 250 CI Inline Six Four speed w/granny low 2003 F350 6.0 Diesel 4x4 CC LWB 1998 Jeep Cherokee Classic Last edited by dakotajeep; 05-17-2010 at 02:44 PM. |
i actually started doing a write-up already look for it soon
Resident of Here
![]() ^^ MORE
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
process:
first i had to make the shims for the front and rear of the frame rails so i had a level bed: the front i used a 19" long 2x4 and a ½ inch shim the rear got a 26" 2x4 and a ¼" shim. this put it pretty level with the mid section of the frame(close enough for me) then i simply set the first 4x4 along the frame rail - i drilled a couple notches with a 1" drill bit to make an opening for a couple rivets and bolts that stuck up so the 4x4 would lay flat on the mid section, i clamped them down nice and tight making sure my shims were appropriate, also I had to notch out for my gas filler neck. . There are 2 risers right behind the cab - i put the first bolt in the second front riser and clamped it nice and tight - i tried to sink the head of the bolts completely so it would not affect the next board. then i cut 4 of the 4x4's to the exact length of 13 2x6's wide. 73 ½" if i remember correctly. i started at the back setting the first 4x4 just above the very back factory hole in the frame about 1 ¾ inches from the end of the frame rail 4x4, i let mine hang over(have plans for it later). I made sure the board was centered by measuring the hangover lengths on both sides they were about 19 ½ inches , I then drilled through both 4x4's and the shim directly above the hole (this alignment was very tricky but i got it in one try on all except 1) i bolted on the very back 4x4 nice and tight! i removed all the clamps since i have the front and rear bolted tight i used 2 of the leftover 4x4 blocks from cutting down the 4x4's and laid them on the 4x4 rail on both sides up tight to the back of the end 4x4 – also made sure they were the exact same length – I slid the next 4x4 up tight to them – then I screwed the filler blocks in place, I had to drill holes in the frame rail for the second 4x4 and then bolted it in place. I wish I could have moved the third 4x4 more towards the cab but the shock mounts were in the way so I measured as close as I could get to it and then cut a second set of filler blocks to that length. Screwed down the filler blocks and drilled holes(frame also) and bolted the third 4x4 down. The very front and last 4x4 was the trickiest because it had the most wood to drill through but I repeated the steps above to mount it – this is where the 5th 4x4 was used since I was out of scrap blocks to use for fillers, drilled a hole in the wood and bolted on the last 4x4. Then I put the 2x6's on and aligned them where I wanted and started screwing them down – I screwed both outside 2x6's on first so they were even with the ends of the 4x4's and let the rest float, but it was a tight fit.
Awesome!!! A picture for me is worth a million words!!!!
Thanks Thad
1968 C10 CST LWB 2x4 Engine: 1975 250 CI Inline Six Four speed w/granny low 2003 F350 6.0 Diesel 4x4 CC LWB 1998 Jeep Cherokee Classic |
driver side right behind the cab those are the 'risers i spoke of
![]() the driver side behind the wheel ![]() looking down the middle ![]() passenger side front ![]() the deck ![]() passenger side ![]()
Sweet. I would then put some sides and a front and rear on it. A guy by the name of Yukon Jack had a nice one on here a few years ago.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
that's the plan - i want to get a roll bar with a closed front - then im going to add some 'skirts' made of 2x8's and notch the deck for some "stake pockets" and make some remove-able sideboards from 2x12's - i will probably get some c-channel and just screw it to the sideboards so i can drop 2x12's straight down for a tailgate, but that would require the sideboards to be very solid - i plan on making them store-able in the opening above the gas tank in the middle.
#13 |
Grandpa in the rustmobile...
pretty sweet! I like it actually! Need a headache rack and something on the sides and some tie downs it'll look sweet when your done!!! Check out yukon jacks flatbed!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#14 |
Resident of Here
#15 |
thats whatcha need bradley!!! wait sarasota, isnt that FL? LOL
#16 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice job on the bed! That would be even more cool with a line-x or rhino lining sprayed over it when done.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#17 |
Junior Member
Thank you for posting the write up and the pictures.
I have been thinking seriously about putting a flat-bed on my '71 since I have always wanted a truck with a flat-bed. The long step-side is pretty rough so I may go flat-bed until I have time to work on the step-side bed. I will just have to wait and see how things unfold since most of my time is spent on the '67 swb stepper restoration. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#18 |
Very Nice, I compliment you on your hard work. What kind of sealer are you going to apply to it? I am debating on doing this to one of my Longhorns.
R/
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
#19 |
i used all pressure treated lumber - someday when it dries up a bit more I might worry about sealing it - ive been doing some tests with some 3M rubberized undercoating that stuff really sticks to the wood nice, if it's dry! and i would love to roll some bedliner over the top more than anything just to make it less slick when it's wet.
but really at less than $150 to build it - i probably wont seal it at all if it rots i will just replace it - it will probably cost more than or close to $150 just for the 3M undercoating at $7 a can ![]()
#20 |
Post Whore
![]() Join Date: Feb 2000
That is very unique!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#21 |
![]() Join Date: Jul 2010
I like this idea. I am thinking about doing this to my 81 K1500 - Do you know what the weight difference is between this wood and the original bed? I just like the idea of a flat bed better. I would just put a headache rack and mud flaps in front of and behind the rear tires, and then coat directly around the tires with bed liner. I would also use pressure treated lumber and apply used motor oil to it all before assembly.
1969 C20 307 SM465, all original - My DD beater project (currently for sale) 1981 GMC K1500 Sierra Grande - my new project. |
#22 |
Not sure about the weight differences
i never really had the original box on the truck with replaced rear springs since this was posted i made some side and back 'skirts' ,and some 2' tall box sides all out of 2x4/6/12etc. it definetly added alot more weight if i had to guess i would say this is probably heavier than the original box
#23 |
That looks Pretty darn Good. Nice job
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#24 |
Naw, can't rhino line it, then you can't see the wood. He needs to stain it, then put a coat of that bar top epoxy resin stuff on it, and let it age and ware with use. It'd look sweet.
68 GMC C2500 - 305 V6 - 4spd |
#25 |
x 2.
How 'Bout them Dawgs! ![]() '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
