Old 05-17-2010, 11:59 AM   #1
channingd
channingd's Avatar
Back to the 1987
Well,
I kind of put this truck on hold after losing my son in a car accident on Halloween. Now I've started working on it again.
How to begin. Let's see. I've changed almost every sensor on this engine and have it running o.k.. It still hesitates a little, more so when it's warmed up. But the main issue is when coming to a stop sign it will sometimes die and will not restart. Really troublesome but I found, not sure how, that when I unhook the battery for 10 seconds and then reconnect, it will start right up. It seems to me for whatever reasons the computer is not letting the fuel pump run and when it's reset, it works fine.
Any direction?
channingd is offline   Reply With Quote
Old 05-17-2010, 12:03 PM   #2
Matt Man
Matt Man's Avatar
Re: Back to the 1987
sorry for your loss. check how much psi is getting to the fuel pump should be getting around 12 psi.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-17-2010, 01:05 PM   #3
channingd
channingd's Avatar
Thank you, and I will check that.
Old 05-17-2010, 11:24 PM   #4
kd71jimmy
Try changing the module under the distributor cap...It happened to me before and it was an easy fix...You can get one from your local parts store...
kd71jimmy is offline   Reply With Quote
Old 05-18-2010, 05:55 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Have you checked the engine codes? Bookmark this website: http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
You can power tune the TBI.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
