05-17-2010, 02:38 PM | #1 |
Which body mount is which?
I have a 68 cab with a 67 1/2 ton SWB frame. The body mount kit I got has one mount that is thicker than the other. Which one goes in the front and which one in the back?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
05-17-2010, 03:00 PM | #2 |
Re: Which body mount is which?
I just bought 1/2 ton mounts and the ones for the cab are all the same. I do believe that the 3/4 ton mounts have thicker ones for the back of the cab, though. Maybe you have the 3/4 ton kit?
05-17-2010, 03:05 PM | #3 |
Project '67 454
On my '67 the two cab mounts with the shorter sleeves go to the front,
67 C-10 SWB Fleetside 454 (current project) 99 Crewcab SWB Dually 454 75 Datsun 280ZZ430 94 Formula 232LS 454 |
05-17-2010, 03:43 PM | #4 |
Interesting. Either my kit is wrong or mclairmo's kit is wrong. mrh33916, thanks for input.
05-17-2010, 03:57 PM | #5 | |
Project '67 454
Luckily I still had the original cab mounts in a box. When I compared the originals to the aftermarket ones I found out that the original sleeves in the front mounts were actually shorter than the rear. Once I made that change my alignment problems went away,
05-17-2010, 07:19 PM | #6 |
Has more rust than truck...
1/2 ton uses a taller mount in the back. Not sure about 3/4 ton, never had one.
