Motor Stands 6 Cly vs. 8 Cly should I use 6 Cly mounts with My 8 Cly ?
Just wondering for better weight transfer ?
Would there be any problems with getting out the Dist HEI style? hitting the fire wall? ' Just Wondering Mario ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Fabricate till you "puke"
I have mine on 6/250 stands......it sets it back 3 1/2" (+ or- 1/8"). The HEI does fit, but is pretty snug. It will go in/out of the eng with the cap & rotor off the dist. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Do you think I should consider using 6 CYL stands?
I like the eng setback, & have done 3 trucks that way. the only downside i can see is that the dist fits a little snug. There are a few upsides, other than the weight transfer........I can drop the oilpan with my eng mounts bolted in place! the drive line is akso a little shorter....1 pc shaft maybe? I also feel that they drive/handle better in the rain/slick with some weight moved back. Its all a matter of personal preferance, & you will no doubt hear many different veiws. good luck.....crazyL
I need a shaft built so that no a worry Iam also thinking Wheelies ! I know it involves a bit more than moving the motor back a few inches. Later
What if?
mine is set up with the 6cyl stands and the hei is real close to the fire wall and the bell housing bolst are a pain to get out but other than that i dont seem to notice much a diffrence. makes getting the headers in and out a whole lot easier too as well as the oil pan.
I think I am going to track down a pair of 6 CLY mounts and use them.
What if?
here is a pic of why said it was easy to drop jeaders in from the top. and one of how close the hei is to the firewall.
2002 red extended cab Silverado 2002 Wheatland yellow Suburban |
What if?
heres the hei
I put mine on 6 mounts but drilled new holes 1" ahead for a bit more hei clearance. Worked for me! I've heard some people say 8 mounts are lower though, any one tried moving these back? I've never really seen these though, don't know what can be done.
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft. 1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power. |
I havent really seen a measureable difference in the height of the smallblock on v8 stands vs I 6 stands.....if anything, I believe it sits a little lower on the 6 stands(approx 1/4").......the later style waterpump (73 up), does however have a greater distance from crank center line to pump shaft centerline , as compaired to the old style pump(approx 1/2").....so if you use the late style pump on a sb in 6 position swap, you may notice that the fanblade is a little closer to the top of the shroud than a factory sb would be......crazyL
THE QUICKER FIXERUPER
I have my v8 on I6 stands, if you guys think your distributor is close you should see my msd pro billit if the engine was 1/8 higher or farther back it wouldent go in and thats without the cap it scared me at first.
#13 |
i used v-8 mounts in the I-6 holes, had to drill new bottom holes, i tried to put it on the 6 mounts but the valve covers wouldn't clear the firewall with tall aluminum covers, it also makes linkage a problem if keeping a stick. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
#14 |
![]() Join Date: Nov 2002
I used the v-8 mounts and moved the engine forward, gives you better HEI clearance and lets you use a small core rad.
