05-17-2010, 03:56 PM | #1 |
glovebox door emblem
I ordered and received a glovebox emblem for my 67. Is there supposed to be some sort of inserts to put in the glovebox door holes because the emblem mounting tabs are much smaller diameter than the holes in the door
1967custom Last edited by michael bustamante; 05-17-2010 at 03:56 PM. |
05-17-2010, 04:08 PM | #2 |
Re: glovebox door emblem
I believe they use barrell nuts....it looks something like this.....I actually cut the tabs off mine and used double-sided emblem tape....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 05-17-2010 at 04:16 PM. |
05-17-2010, 04:09 PM | #3 |
Mine fit nice and snug, I had to push it pretty good to get it in there. Maybe your holes are a little wallowed out? You could try wrapping the tabs in something to make them thicker or if you haven’t painted yet just fill the holes and drill some new ones to the correct size.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
05-17-2010, 06:37 PM | #4 |
Napa usually carries the barrel nuts.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-17-2010, 07:49 PM | #5 |
Need a bigger hammer..
I used dbl sided tape.
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
05-17-2010, 09:13 PM | #6 |
I tried the barrel nuts but ended up using double sided tape. It's held up for several years now.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
05-17-2010, 11:11 PM | #7 |
Sofa King Crazy!!
I just ditched the whole emblem and went custom, and only had to drill 7 holes!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
