Old 05-17-2010, 07:17 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Need a 5 lug rearend, what're my options..
I currently have a 68 373 6 lug rearend blasted and painted nice.
I aquired a 5 lug 373 that everyones saying the gears are junk in.
I need a 5 lug rearend to run some wheels I got. What're my optons?
1-ECE conversion axles $$$$$
2-keep hunting for good 5 lug rearend
3-drill my current axles (is that safe?)
4-get 73+ rearend (fab skills i dont have)
5-other
thank you
John
1999 Toyota Tacoma 4x4
Old 05-17-2010, 07:21 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: Need a 5 lug rearend, what're my options..
l think 5 lug 71-72 rears are narrower by an inch or something i think. So that option wont work i beleive. If they are wider i dont know if a machinist couldnt cut them down for you and then you could use them.
Or have a machinist redrill your current axleshafts (if they are usable) or order some 28 spline axles from summit in the correct length for your 6 lug rear.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 05-17-2010, 08:08 PM   #3
David67
David67's Avatar
The later model years 70-72 are the wider axles. The 67-69 axles are 30.75" while the later ones are 31.5". I've ordered a 5 lug conversion from CPP that is currently on backorder. It comes with the 5 lug drums and a new gasket as well for the differential cover.
Here's the link:
http://www.classicperform.com/Store/...k/6569RACK.htm
David67 is offline   Reply With Quote
Old 05-17-2010, 08:12 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Keep looking for a 71-72 axle.
Keith
Convert to disc brakes.
Old 05-17-2010, 08:15 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
If it were me, I would ether try to find an entire 71-72 rear or just take both rearends to someone and have them put your 68 gears in the 5 lug housing. You could even do it yourself if you have the time/know how...well dont even need the know how, just ask someone on here!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-17-2010, 08:21 PM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I would say take both to someone who knows how to swap gears. Don't do it yourself, I've rebuilt multiple engines, pulled tons of engines and trannies, and lots of other stuff with no trouble, but when I swapped gears I ended up with a carrier busted in two pieces.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-17-2010, 08:23 PM   #7
Walts_restoration
Doh! i was thinking this but forgot to add it. If they are both the same rears then just swap gears from 6 lugger to the 5 lugger, well if everything else in the 5 lug rear is good and its straight.
Old 05-17-2010, 08:52 PM   #8
Shane
Shane's Avatar
pick up a '73-'87 ... salvage yards are full of them and they're cheap ... then buy some 3" axle perches and pay someone to weld them up for ya.
I would almost bet this is still cheaper than finding a '71-'72 rear
Shane is offline   Reply With Quote
Old 05-17-2010, 10:40 PM   #9
oldblue1968chevy
cool guys keep it comming!
I just sold a 73-87 rolling frame for 75$ to my buddy ima have him open it up and check gear ratio may go that way
or I may buy conversion axles not sure yet...
swapping internals sounds really $ right now...thanks keep it comming!
John
Old 05-17-2010, 10:47 PM   #10
lolife99
lolife99's Avatar
Is your truck leaf or coil sping?
If you put a 73+ rearend under a coil spring truck, you have to use a Super Track Bar like ECE sells.
(since there is no provision for it cast into the center section like the 67-72 rearends).
Keith
Old 05-17-2010, 10:50 PM   #11
oldblue1968chevy
Its coil springs. What should I pay for a GOOD rearend? Im going to goodguys in nashville think I could score a rearend there? Or conversion axles? Thanks lolife!
John
Old 05-17-2010, 10:55 PM   #12
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I would think you could get the gears swapped for less than axles would cost.
chevytruckluver is offline   Reply With Quote
Old 05-17-2010, 11:02 PM   #13
oldblue1968chevy
Really?
But I would still have to sandblast and repaint everything..Im lazy lol but I can work harder if im saving $
What kind of shop would do rear diff. work? Thanks!
John
Old 05-18-2010, 01:16 AM   #14
jbristo67
resident oilfield trash
jbristo67's Avatar
I have a 72 chevy rear in my 67 with no mod.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-18-2010, 01:35 AM   #15
mr48chev
mr48chev's Avatar
It will probably cost just about the same to have someone swap the gears out as it would to have the axles redrilled.
You can send the axles off to Moser or one of the other shops that does it but usually one of the local machine shops can do it for a reasonable cost. You would want to take them the studs you want to run though so they get things right.
Old 05-18-2010, 01:56 AM   #16
c10seconds
c10seconds's Avatar
Just get your 6 lug axles drilled. It should cost less than $100.00. Thats what was done to the axles in the rear end I just removed from my truck. I never had any issues
c10seconds is offline   Reply With Quote
Old 05-18-2010, 02:09 AM   #17
c1069
c1069's Avatar
Keep looking ..........recently found one, do not worry. find one like me
c1069 is offline   Reply With Quote
Old 05-18-2010, 10:24 AM   #18
mdwilf
mdwilf's Avatar
Use the longer 5 lug axles in your older rear, then get the wider brake drums for the later 70's trucks (2 3/4, I think) & they will cover the brake shoes. You'll have to use the narrower shoes (2").
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 05-22-2010, 11:01 PM   #19
jbristo67
jbristo67's Avatar
I know where 4 or 5 5 lug rears are
2011 Nissan Armada
Old 05-22-2010, 11:05 PM   #20
oldblue1968chevy
Will that work? :S Mdwilf? Thanks!
jbristo, your in TX lol
John
Old 05-22-2010, 11:43 PM   #21
mdwilf
mdwilf's Avatar
I've driven one that way for a few thousand miles & I'm doing it in the restoration I'm doing right now for a customer/friend. I was told that trick by someone who knows this era of trucks better than anyone I've ever met.
If you want to test my fix, measure the axles & see how far they are the same diameter - measuring from the end of the axle towards the "pumpkin ball" end. Then remove your old axles & measure the width of the axle bearings. Install the axle & then measure the gap from the bearing to the end of the axle & add the width of the bearing. If that total is less that the 1st measurement (distance that the axle is the same diameter) then you are good.
You might be able to cifer all this out by measuring the wear marks on your old axles.
Install your 2" wide brakes & put on the 2 3/4 drum. You will find it covers quite nicely.
I hope this all makes sense. It's late for an old man!!
Old 05-23-2010, 07:11 AM   #22
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
not sure of the year (seller never posted it) but maybe this will work
http://chattanooga.craigslist.org/pts/1711898392.html
good luck
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-23-2010, 01:08 PM   #23
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i don't recomend the long axles in a short rear end. While it'll probably work for a long time, the bearings will be riding on a non hardened surface, and there's more leverage adding stress to the shafts.
Do it right the first time and you won't be stranded with a snapped axle shaft and a wheel sticking out an extra foot and/or damaging the bed side.
Old 05-23-2010, 01:32 PM   #24
fastom
That's right, it's Copper!!
fastom's Avatar
Summit Racing sells replacement axles for our trucks!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 05-23-2010, 10:42 PM   #25
mdwilf
mdwilf's Avatar
I'm asking - not debating - is the "hardened spot" really that small?
