How do I post an photo
What is the easiest way to post a photo?
Re: How do I post an photo
I'm no expert, but when you type your post, scroll down to Attach Files and click on the Manage Attachments block. You should get a pop up to Browse, click on browse and you will be searching your computer for pictures (probably in your My Pictures) folder. When you find the picture you want to upload, double click on it and it should appear in text form in the first open block in the pop up window. Then click the Upload tab and your picture should upload to your post (might take a while to upload - just wait). Go to the post you are typing and click Preview Post at the bottom to see if the picture posted. If you want to post another picture, go to the second block down from the top, and on down the line for all of the pictures you want to post. You can select all of your pictures at one time then check Preview Post to see how the look before you Submit Reply.
Thanks, it worked as described.
Randy |
