Old 05-17-2010, 08:48 PM   #1
k5blazin
now i am moving forward!!!
sand blasted, primed and the old rustoleum semi gloss.. busy weekend. turned out pretty nice! next order of business is a 4 inch suspension lift... any suggestions? i was looking at the rough country! thanks
k5blazin is offline   Reply With Quote
Old 05-20-2010, 02:24 AM   #2
chevyblazer
chevyblazer's Avatar
Re: now i am moving forward!!!
hello that chasis looks great keep going dont stop
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 05-20-2010, 10:47 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I like Tuff Country Ez-Ride springs, that is what I have on my 69 K20. Is the blazer body in the background going back on this frame? Is it an optical illusion or is the body actually bent?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-20-2010, 02:27 PM   #4
k5blazin
thanks!! there is no stopping now! lol
Old 05-20-2010, 02:31 PM   #5
k5blazin
i was also lookin at the tuff counrty! are you using the 52" or 56 " springs, and or shackle flip? the black blazer is for parts only, it sure is bent. lol
Old 05-20-2010, 05:04 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm using the stock length 6" springs on the front of my 69 K20 with the extra spring that they put in to make it a heavy duty pack. For the rear I'm using my stock springs with a couple extra springs added, with the stock block and ORD's 4" shackle flip. Be aware the shackle flip will move your axle forward which makes the tire very close to the front edge of the wheel well and makes it look very uncentered. A Zero-Rate with offset center pin can help correct that problem.
On my 70 K5 I am running 4" Skyjacker front springs and stock rear springs with a 3" block and custom spring mounts built for the 14 bolt that I installed.
I like the Tuff Country springs better ride wise compared to the Skyjacker springs but honestly, they both are fairly bouncing depending on the road surface. No Cadillac ride for sure.
Old 06-12-2010, 11:12 PM   #7
k5blazin
more progress. nice parts wes. thanks for the bed rochlow.
Old 09-10-2010, 09:49 PM   #8
Rochlow
Hey.. I recognize that bed side... Did you use the other side as well?
Rochlow is offline   Reply With Quote
Old 09-10-2010, 10:02 PM   #9
k5blazin
i used the whole bed! i am now fixing the bad spots, it coming really nice! how is your project coming along?
Old 09-10-2010, 10:04 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-10-2010, 10:16 PM   #11
k5blazin
thanks va72 here is my drivers floor almost complete! wow i never thought it was going to be so time consuming! worth every second though!
Old 09-10-2010, 10:18 PM   #12
Rochlow
Cool... I'm having problems adjust the doors. I have to put about 6-7 shims in the latch to get it even come close the closing. I need to put a post about it to see if anyone has a solution..
Old 09-15-2010, 09:11 PM   #13
k5blazin
thinking of going with these h2 wheels and using these 6 lug to 8 lug adapters http://www.ezaccessory.com/ProductDe...-8650&click=35
anyone tried these? what do ya think?
Old 09-15-2010, 09:58 PM   #14
coggonobrien
don't use adapters, not very safe
coggonobrien is offline   Reply With Quote
Old 09-15-2010, 11:25 PM   #15
AJs72K5
AJs72K5's Avatar
Agreed. Don't go cheap or sacrifice safety with all of this work nice work you are doing Take the time to swap in a set of 8 lug axles if you want to run those wheels.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 09-16-2010, 07:48 AM   #16
Rochlow
if your looking for axles for those.. I have a friend that has some Dana 60's?
Old 11-06-2010, 10:03 PM   #17
k5blazin
more progress! 4 inch lift installed.. picked up some nice fenders also... still looking for doors...
Old 11-06-2010, 10:26 PM   #18
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 11-06-2010, 10:46 PM   #19
coggonobrien
what did you use for a lift kit? any tricks to do it?
Old 11-07-2010, 04:57 PM   #20
k5blazin
4 inch tuff country..it is pretty simple to do if you have a good set of tools. i had to heat my spring bolts in the front hangers, so you might need a torch also..
Old 11-07-2010, 05:53 PM   #21
coggonobrien
did the kit require you to reset the angle of the rear pinion or did it include blocks that took care of that? also are you using stock driveshafts or somethign with better u-joints?
Thanks,
David
Old 11-07-2010, 09:39 PM   #22
k5blazin
Thanks,
David
the rear blocks are angled to compensate. stock drive shafts look like they will be fine. i will not be doing any major off roading.
Old 11-08-2010, 01:34 AM   #23
coggonobrien
gotcha, so its a front spring, rear block lift? any other issues you ran into? sorry to be nosey, i'm an engineer and a farm so I like to do things right going into them.
Old 11-08-2010, 08:38 AM   #24
Jtrux
I'm a poor spectator
Jtrux's Avatar
Nice progress, out of curiosity why did you paint the chassis before doing the body work, I just figured with all the welding, grinding, primering and painting the freshly painted frame would be bound to get a little dirty. Not knocking you by any means, just wondering.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-08-2010, 06:17 PM   #25
k5blazin
Not sure if they all have this but on my left front spring hanger there is a brace welded underneath . I had to cut the welds and bend this down to allow the new front spring!
