05-18-2010, 02:28 AM | #1 |
Neutral Safety switch
So I just put a solenoid relocation kit on my truck from Jegs, this is my fourth starter in a year and I bought the starter wrap. To fix my starting problem, crossing my fingers this holds up. But ever since I put the new solenoid on my neutral safety is acting funny. Like sometimes it will start in park but most of the times it will not. By the way it is an automatic. and sometimes in won't even start in neutral I will have to move the shifter up and down and get "lucky" to have it start. I would just like to by pass the thing entirely. Any tips on how to? Thanks guys!!!
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html Last edited by fire120ball; 05-18-2010 at 02:29 AM. |
05-18-2010, 06:55 AM | #2 |
Re: Neutral Safety switch
I wouldn't remove the neutral safety switch. If your linkage is so insecure that you have to fish for the proper switch operation, you very well could injure or kill somebody, including yourself if you start in gear. Fix it properly.
05-18-2010, 08:01 PM | #3 |
If I started in gear it would bump the truck forward... Then I would say O f*** then change it, its not that it is insecure. The wiring is messed up.
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
05-18-2010, 11:30 PM | #4 |
Another Day, Another Dollar
it seems a bit odd to me that you have nuked 3 starters in 1 year.
perhaps there is a deeper root to the problem?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
05-19-2010, 02:43 AM | #5 |
That is what I was thinking too, but I asked around on this forum and with headers I GUESS it is a very common problem? even with everything I did. Relocate solenoid, wrap my starter. It still does not start hot. I have routed wire's so the wires are away from any type of heat. I have changed the battery, Changed the power and ground wires. I'm just stuck, now this neutral safety thing. God I don't even know what to do...
05-19-2010, 03:21 AM | #6 |
In the Forgotten far North.
Get rid of the problem by getting rid of the headers. Problem solved.
If it's headers you want then get some "shorty" headers
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
05-19-2010, 05:24 AM | #7 | ||
Initial timing. A little to much can hammer the starter. On mine, it was fine cold, but warmed up it was slow cranking and sometimes would "backlash" (everything I read told me it was the heat from my headers also. Until it first "hammered") I'm currently running cheap Heddman longtubes, and my starter has been happy there for about a year and a half now. (knock on wood)
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
05-19-2010, 11:38 AM | #8 | |
cheap heddman longtubes, 12* of initial timing, no starter wrap, no header wrap, no problems :] hot or cold i'd double check your timing again
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
