Old 05-18-2010, 12:33 PM   #1
trevota
fuel sending unit
Hey guys. when i bought my truck just over a year ago, the fuel gauge didnt work. So i went to the classic car parts store and ordered a new sending unit. The fuel gauge now works, but not accuratly. After some research I found that the stock sender was 30ohm resitor and the one i bought was a 90ohm. Is there anyway to make this one work? I've called around and no one can get the proper one.
Thanks,
btw its a 65 c20
trevota is offline   Reply With Quote
Old 05-18-2010, 01:17 PM   #2
frmula505
frmula505's Avatar
Re: fuel sending unit
You could try running a 45 ohm resistor in parallel with the sending unit. Not sure if it will effect linearity. It will get you to the 30 ohms
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 05-18-2010, 02:30 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I build new 0-90 ohm fuel sending units for the stock tanks, if you're interested. I have one on my shelf in my office ready to go. Check the link below for more of a description if this is the route you would like to go for the sending unit.
http://67-72chevytrucks.com/vboard/s...d.php?t=288717
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-18-2010, 04:32 PM   #4
WRO44
I just bought a new 30 ohm one from Classic Parts of America...should be here tomorrow. I will let you know how it works!
WRO44 is offline   Reply With Quote
Old 05-19-2010, 08:33 PM   #5
trevota
If it works let me know then send me their contact info.
Old 05-20-2010, 12:44 AM   #6
'63GENIII
'63GENIII's Avatar
You can also rewind the wire in the sending unit leaving out 2/3 of the wire that it came with, giving you the 30 ohm total resistance that you need. No B.S. it works, just did one on the '63 that I'm converting to fuel injection with a stock '91 tank and sending unit. I didn't have the money to have the sender reworked so I did it myself. Works perfect.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
