WHYBYNU when old will do
Tire pics please...
Anyone running 255/60/15 on front with 275/60/15 rear ? I'm looking at this for my new TT II . Any pics would great
Thanks John
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
14.1 @ 96MPH
Those are my old Radial T/A's. 245/60-15 front, 275/60-15 rear. I can't get 255's to fit up front between the drop and the disc conversion (2.5" drop front, 4" rear, ECE 6 lug disc conversion)
Project1970 - LS1 Swap Complete! ![]() |
Thanks Project1970 for the pic. I love your trucks stance ! what was the problem with the 255/60's and your drop.
By the way how do you like your new Yokohama's? Thanks John
14.1 @ 96MPH
Between the discs which widen the front track up a little bit and the drop, I was getting rubbing problems with the tires that were on there before - which were actually 245/70s or something, I don't remember, they were old and dryrotted T/As.
I say I can't go anything bigger than 245/60 because I have managed - only once or twice in three years, though - to get them to rub on the fender. (when the suspension is compressed). I would imagine that tolerances are close enough that even a 255/60 would be a little too wide up there. If/when I ever find the budget / time / desire to convert the truck to 5 lugs (just need, aside from rims/tires, 1971 rotors, rear drums, and rear axles, and the last two can be modded), I'll make sure to get a backspacing that allows me to run taller tires up front, though, just because I'd like to fill out the front wheelwells a bit more. The Yokohamas rock. ![]()
14.1 @ 96MPH
I should note that I don't know if factory disc trucks have as wide of a front track as converted trucks like mine, so you might be able to tuck some bigger rubber under the front.
Thanks for the great info. The reason I wanted to know is I just ordered 275/60 and 255/60 Yokohama's Avid S/T from Summit Racing maybe 20 min. ago. I beleave the disk convertion does add about 1-1.5 inches to the front.
I read a tire comparison and Yokohama's blew TA's off the chart and just about all other tires in the same cat. Thanks again for the pics and info...... John
14.1 @ 96MPH
Yeah, the Avid S/Ts were very highly rated, and every bit of my experience with them agrees. My truck was nearly undrivable in the rain with even new Radial T/As (between that and my too-stiff THM400, I got more than my share of scares around corners); right before I got the S/Ts, I got to deal with driving I-10 from Tucson to Phoenix in a downpour with nearly worn out T/As. Yeah, that was interesting, in that I-can't-go-faster-than-60-because-I'm-hydroplaning-like-a-mofo way. Ugh.
With tires like the S/T's out there, I have no idea why Radial T/As still sell, let alone for the premium price they get. They're not only one of the worse tires in their class, they're one of the most expensive, behind only Michelin, I believe. Oh, and if/when you take it to the track, hehe...the Avid S/Ts work GREAT at street tire pressures (I never bother changing them), just give them a quick scratch burnout to warm them up prior to your run. No waterbox.
Active Member
255/60 fronts on 15x8's with 4" back space also 2 1/2" drop spindles and disc conversion, 275/60 rears with 4 1/2 back space on 15x10's and 3" drop spings. sofar no rubbing.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
71 Cheyenne with 275/60's on 15X8 front and 15X10 rear.
![]() ![]() Join Date: Jul 2002
Not real clean or High-techie...but I am running 275/60 x 15 on stock 15x8 ralleys at all 4 corners I like how it looks and that they are all the same size. My spare will match someday.
oooops tooo early for operating a mouse. here is the picture
Mike
I had BFG TAs on my camaro,couldn't drive in the rain.I put Pirelli tires on.They where cheaper and the car handled way better.They seem to have a softer compound because they wore faster.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#13 |
This is 255/60/15 on a 7 inch rim and 275/60/15 on a 10 inch rim.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
#14 |
here is a better pic. The guy before me used a torch to lower this, so there really isn't a exact lowering stance to it.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 Last edited by chaptr2; 02-13-2003 at 11:25 AM. |
#15 |
Junior Member
Chaptr2,
Love the look of your rig - Would you know the Backspacing for those rims. |
#16 |
i don't have any probs with 255/60's up front. i am running an 82 front suspension, i dont know if the track width is the same or not i'm guessing it is
68 short step, 406/700r4, 9" w/discs. |
