Old 05-18-2010, 09:13 PM   #1
nastynate
Question question about converting front disc brakes on 67 c10
just recently bought a 67 c10 with the front drum brakes. want to convert to front discs. have a set of 71/72 OEM front spindles. will they mount up to the 67 control arms properly? Just use 71/72 ball joints, tierod ends, rotors, hoses,calipers, right?
nastynate is offline   Reply With Quote
Old 05-18-2010, 09:44 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: question about converting front disc brakes on 67 c10
Yes I pressed some 71 balloints (top and bottom) into my control arms, and used the 71 steering assy. and added new tie rod ends also. Then used some braided hoses I got from...ECE I think, inline tube made them. They were conversion hoses, just over 100$. You could also get rubber oem style for cheaper. Good luck any ? Just ask. You also need a 71 MC and prop. valve..
John
1999 Toyota Tacoma 4x4
Old 05-18-2010, 10:02 PM   #3
nastynate
Oh, ok. so the 67 manual steering assy. will not work with the 71 spindles?? Thanks alot for the help!!
Old 05-18-2010, 10:15 PM   #4
leddzepp
Moderator
leddzepp's Avatar
You need a 71-72 centerlink too.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-18-2010, 10:28 PM   #5
oldblue1968chevy
No I think you can buy conversion tierod ends somewhere..I may be wrong though
I just grabbed the whole steering assy.
John
Old 05-18-2010, 10:30 PM   #6
leddzepp
Moderator
leddzepp's Avatar
If you do not use the 71-72 centerlink, you will need to use different inner tie rod ends.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
