Old 05-18-2010, 11:05 PM   #1
cweber
4.3L Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=403360
cweber is offline   Reply With Quote
Old 05-19-2010, 09:40 PM   #2
cweber
Re: 4.3L Swap
Anyone? I have found a few things on the net that make me think there isnt much difference.
Old 05-22-2010, 11:10 PM   #3
clinebarger
Re: 4.3L Swap
The knock sensor thread pitch & diameter are different between a 96 & 04 (you cant use your knock sensor on a 04 engine). what I do is drill & tap the newer engine for the older style knock sensor. Is it a manual transmission? If so you will need a 04 pilot bearing drivin in at the right depth.
clinebarger is offline   Reply With Quote
Old 05-24-2010, 08:51 AM   #4
cweber
Re: 4.3L Swap
My 96 is an auto, but the 04 is a manual. I will have to change flywheels, should be the only thing. What if I leave the knock sensor in the 04 motor, will it plug into the 96 harness?
Old 05-24-2010, 09:43 PM   #5
clinebarger
Re: 4.3L Swap
It will not plug in. Your 96 uses a 1 wire broadband sensor, The 04 uses a 2 wire flat responce sensor. Drilling & tapping the hole from 8x1.25 MM too 1/4" NPT & installing your 96 knock sensor is manatory. Its not that hard drilling & tapping cast iron, take you time.
