Old 05-19-2010, 08:55 AM   #1
smith2481
71-72 gas pedal swap
Hey I have a 70 c10 and I got a 71-72 pedal assembly off a member on here with everything does anyone know how hard it is to install of any threads on here about it any info appreciated thanks
smith2481 is offline   Reply With Quote
Old 05-19-2010, 09:11 AM   #2
8mpg
8mpg's Avatar
Re: 71-72 gas pedal swap
get the conversion bracket from LFD and it will bolt up. Then you just need a cable
8mpg is offline   Reply With Quote
Old 05-19-2010, 09:26 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
ummm subscribed I need to get a 71/72 peddle for my caddy tranplant...
pics help!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-19-2010, 09:28 AM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
you can also do this mod by putter :
http://67-72chevytrucks.com/vboard/s...00#post1383300
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-19-2010, 09:45 AM   #5
Hottrucks
Hottrucks's Avatar
that seems easy enough to do I like not having to drill more holes..not sure if you could reuse the original plate instead of building a new one
Old 05-20-2010, 12:10 AM   #6
67Slider
67Slider's Avatar
I did the same thing to my 67. Here is my post:
http://67-72chevytrucks.com/vboard/s...d.php?t=394112
If you run into any issues LFD did a real good write up on it and that is how I did it. You can fabricate it yourself or buy LFD's kit. I made mine out of some sheet metal leftover in the garage.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 05-20-2010, 02:12 PM   #7
JesseH13
AMBITION
JesseH13's Avatar
i did not use the adaptor kit i did mine but just redrilling hows and coverning the old pedel hole it works perfect i did not want to spend the money on adaptor just do it my self
1979 Nova-daily-R.I.P
1976 c10 "daily"-
1968 c10 -project
CROOKED68 (PROJECT)
JesseH13 is offline   Reply With Quote
Old 05-21-2010, 06:52 AM   #8
smith2481
wow thanks for all he replys guys I will do putters mod looks easy and cheap lol thanks again
