Moderator
![]() Join Date: May 2007
I will be swapping in an HEI unit in my 72 big block. I have heard there may be clearance issues with the cap and firewall. Are there any issues, or is there enough clearance? Will I be able to drop the distributor in after the engine is put back in the truck, or do I need to do it before? Thanks in advance.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: HEI firewall clearance on a big block
they wouldn't have put big blocks in at the factory if you couldnt take the dizzy out after it was installed... that would just be a terrible decision. I do notice that the firewall clearance is tight with my sbc though, however I'm not sure that big blocks sit any higher than sbcs, I've never measured.
1968 LWB C20 / AC / Wood Bed |
Moderator
HEI was not put in at the factory on our trucks, this is why I am asking.
subscribed....about to run into the same problem, that is, if it is a problem?!
I put a Skip White HEI dizzy in my 70 GMC w/a BB (396/400/402).
No problems at all. HTH...don t. ..... |
The HEI would not fit right on my 71 4X4 small block! I don't know if that is usual! It was to close to the fire wall.
Factory Strippers Rule!
![]() Join Date: Mar 2009
In 4X4's, the engine sits farther back, that is why there is a clearance problem with HEI hitting firewall.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
Moderator
I have HEI in my 72 2WD small block truck. It fits with no issues. I will be putting one in my other 72 2WD big block truck.
Under Construction
Ledd, I have seen several BBC 67-72 with hei's....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#10 | |
Moderator
![]() Quote:
![]() Join Date: Jan 2001
Mine fits swell in my '72 402
![]() Join Date: May 2009
Same with mine. The back two screws are a little tricky to get at, but it fits fine.
#13 |
there's plenty of small cap HEI dizzys on the market if interested in that route
#14 |
Under Construction
Yeah i forgot to mention that skip white performance carries the small cap dist. as well.
#15 |
My 67 2wd with a bb and custom made engine mounts was really close. I just "massaged" the firewall a bit and it works. Its pretty close, but it works just fine.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
#16 | |||
Moderator
#17 |
![]() Join Date: Oct 2002
no clearance problems with factory bb mounts , clears fire wall by 1/4 in sb with it set back 7'' on reverse 6cyl mounts as far as it can go .if it hits your cab mounts need replacing.
#18 |
Ive got aftermarket BB mounts and I am not able to take out my HEI unless I unbolt the motor. I can barely get the driverside valve cover off and on. My motor sits really close to the firewall for some reason
#19 | |
Moderator
#20 |
Going back for another run in sept.rust free parts are hard to find around here and everywhere out there.Last couple of trucks came from sacramento and san fran area.I am looking at some in southern ca right now .might catch up with you for a quick hello on this trip.I like the way you are building your truck and doing the work.progress looks good and nothing like the pride of a job well do when you get finished.
#21 | |
Moderator
#22 |
i got an accel distributor with the coil pack on top of the dist. and i had plenty of room on my 402
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#23 |
"THE GREEN GOBLIN"
No clearance problems with 72 factory bb mounts But then again Im useing a MSD Dizzy & the cap is alittle smaller. my tall valve covers come off fine up & forward not straight up.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#24 |
2WD Jimmy
![]() Join Date: Mar 2005
MSD dist and valve covers with stock 72 mounts
#25 |
"THE GREEN GOBLIN"
WoW thats one nice motor..
