Rollin' Old Skool
Opinions: 71-72 vs. 73-87 front crossmember
hey guys,
i'm looking to do the 5-lug disc/drum swap...i've found a 72 with the rear end & gears i want...it also has the front crossmember with power steering/brakes...in my research though, i've read that there are some advantages with the 73-87 having rubber bushings...so, i'm unsure what to do...my initial plan was to find a 71/72 rear & 73-87 front crossmember...however, i didn't expect to find a complete 72 5-lug chassis...can anyone with experience list the pros/cons...should i just get the rear & hold out for a 73-87 front? or just get everything for the 72? just for reference, my truck is a '66 short/fleet....later i plan on a 4.5/5.5" front drop, & 5" rear...this isn't a truck that will be driven daily...it's basically my weekend cruiser & show 'n' go truck...but i do want it to be road worthy enough to travel "comfortably" long distances every now and then thanks for any help |
Re: Opinions: 71-72 vs. 73-87 front crossmember
71-71 a-arms are just like what you currently have on your 66; 73-87 have the more 'pliable' rubber bushings which transmit less road noise & vibration. Think of the 6x-72 bushings as rubber lined steel sleeves. You feel more because they deflect less. The question would be is the softer ride of the later bushings more important to you?
Rollin' Old Skool
of course, i want it to be as comfortable as possible with a considerably lowered stance...but what i'm not sure of is how much of a difference is there between the two? drastic or not? considering this isn't something that will be daily driven, is it still worth it to go with the 73-87? that's where i'm stumped......so i guess i'm trying to figure out how much better of a ride will i have with the '73-87? if it's a very noticable difference, i'll hold out for the 73-87....if not, the 72 will have everything else i need
Resistance is Futile
I have one of each bushing type and can tell no difference. I believe tires,coils, and shocks play a more important roll.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#5 | |
I've used more of the 73-87 stuff doing conversions because it's easier to find in a wrecking yard vs. 71-72 stuff. I used 71-72 stuff for my 68 when I did the disc swap because it was an easy find. I haven't noticed much difference vs. my 74 (both trucks were lowered similarly w/dropped spindles w/1-coil cut).
No debate about the cost of the newer stuff being more 'budget friendly'...
I would prefer the newer style bushings, however on a budget i took what i could find cheap, which was a whole 72 chassis for 200 bucks.
Can someone post the thread on swaping a 73-87 front member/suspension on a 60-66. I looked but could not find....
Please? Thanks! Chris Last edited by Chris65GMC; 05-19-2010 at 08:36 PM. |
#9 | |||
Rollin' Old Skool
http://67-72chevytrucks.com/vboard/s...ght=disc+brake you can also look at Tx Firefighter's build thread for some pics of his swap...i'm sure there are several other members who have done this swap as well...you can browse through the build threads |
Rollin' Old Skool
any other opinions? i plan on looking at the 72 this weekend
I have used both designs and can't feel any difference in the ride. To me, the advantage of the 73-87 is that the bushings don't need to be greased. Also, you might prefer the later engine mount design.
If you find a 71-72 setup, you don't even have to swap the crossmember. Just unbolt the control arm shafts, which is a lot less work. If your truck isn't going to be used as a daily driver, the greasing should be a non-issue. Ray Last edited by raycow; 05-25-2010 at 07:17 AM. |
#12 | |
#13 | |
Ray |
#14 |
Now for clarity this is for the 63-66 right? I have a 62 torsion bar set up so I will need the entire crossmember setup be it 72 or 73 not just the a-arms and spindles
#15 | |
Rollin' Old Skool
i believe that is correct |
#16 | ||
The 63-66 suspension is similar to the 67-72 w/the steering box/linkage slightly different (actually it's the 63-67's that are different). Quote:
#17 | |
Ray Last edited by raycow; 05-25-2010 at 11:16 PM. |
