02-12-2003, 11:13 PM | #1 |
Difference in 3 speeds
I would like to know which is which. I have the three speed with 7 bolts on the side cover. Is that the saginaw or the muncie. Can you tell me how to distinguish the difference. I think on has 7 and the other has 9. Which is which.
02-12-2003, 11:53 PM | #2 |
Fabricate till you "puke"
The saginaw has 7 bolts on the side cover, & is a medium duty trans(they will take a little guff). There were a couple muncies over the yrs, 1 we called the old "2 pin" muncie(from about the mid 50s, to the mid 60s) ......it was a very short case,1st gear was not syncronized & if memory is with me , it had 4 bolts on the side cover. There was also a later muncie 3 spd that was full syncro, & was a pretty beefy box.....im not positive, but think this one had 9 bolts on the side cover. I would have to dig out a couple old books to get all the details....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-13-2003, 12:08 AM | #3 |
Is the Saginaw a fully syncronized tranny?
02-13-2003, 12:09 AM | #4 |
difference in three speeds
02-13-2003, 12:14 AM | #5 |
yes, the saginaw is fully syncro....crazyL
05-28-2003, 04:14 PM | #6 |
Progress = 0%
Hey Brian,
You still owe me $60.00!!! Pay up!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
