Old 05-19-2010, 10:41 PM   #1
jsmithbm
jsmithbm's Avatar
calling on 350 3tt owners
Hey guys, i am button up a 350 swap from inline 6 cyl. I need to ask a big favor. I wanted to see if you could post some pics of the drivers side of the engine and transmission mount. Thanks a lot
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 05-20-2010, 11:08 PM   #2
jsmithbm
jsmithbm's Avatar
Re: calling on 350 3tt owners
anybody
Learning as I go!
Old 05-20-2010, 11:31 PM   #3
1968CHEVYC10
1968CHEVYC10's Avatar
I've got that setup in my '68, if you could be a little more specific about what you want a picture of I can get you some pics in a few min.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 05-20-2010, 11:36 PM   #4
jsmithbm
jsmithbm's Avatar
Well I would like to see the tail shaft brace at the rear of the tranny and maybe the length of the drive shaft from weld to weld and a photo of the clutch linkage. I know that's a lot to ask.
Learning as I go!
Old 05-20-2010, 11:39 PM   #5
1968CHEVYC10
no problem I'll see what I can do. be back in a few min!
Old 05-21-2010, 12:20 AM   #6
1968CHEVYC10
ok here we go, I'm not sure I understood 100% what you were wanting but here's what I got:
this is the tail shaft of the tranny, I didn't see any brace for this except the brace closer to the clutch
this is a different angle of the crossmember
and here's some shots of the driveshaft
Old 05-21-2010, 12:25 AM   #7
1968CHEVYC10
the next few are of the clutch linkage, it was kinda hard to get to so not the clearest.
Old 05-21-2010, 02:22 AM   #8
CSGAS
optomistic ah-so
CSGAS's Avatar
Mine also came from the factory with the "rear engine" or bellhousing mounts system instead of the tailshaft crossmember common to cars, 4-speeds, later trucks, etc. There should be pairs of holes in the rails that line up where you want them to, I think the Powerglide equipped trucks would use the ones you would want. (anyone who can help on that count?)
For driveshaft length, are you putting this in a shortbed or longbed? Also, if you can wait a day or two I can get a good shot of the plate holding the linkage to the block, it doesn't show as should be informative.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 05-21-2010, 06:44 PM   #9
jsmithbm
jsmithbm's Avatar
thanks guys, its a short bed step. There are a tone of pre-drilled holes on the frame. i have the original tranny mount still in the truck and a mount on the tail shaft. i like the bell houseing mount that you have in the pics better. i need to find one at the junk yard.
CSGAS i got time! take your time. thanks
Learning as I go!
Old 05-23-2010, 06:06 PM   #10
jsmithbm
jsmithbm's Avatar
that bellhousing tranny mount looks like the one i have now, hmmmm
Learning as I go!
