![]() Join Date: May 2010
Biggest size tire
What is the biggest tire size you can fit on stock suspension and on the 15" rims?
its all about the +6 inches
Re: Biggest size tire
2 wheel drive or 4X4?
how wide a 15 inch rim you talking? You want big as in tall, or big as in wide, or do you want both? |
Short answer. 33" -- tight - doable, but tight -- might rub some at full turn and big bumps. 31" will fit with no rubbing.
Good enough?
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Sorry guys this is 2wd lwb.
somewhat wide and tall would be nice. However if 31" will fit that will be great! |
The Engine Whisperer
i believe the widest you can fit with a factory coil is 17" wide or 18" wide, someone will correct me if i'm wrong. But yes, 31" tall tires will fit with no issues
