Old 05-20-2010, 01:58 PM   #1
crakarjax
crakarjax's Avatar
Can't get my fan shroud on...
I left my fan shroud off when I had my water pump off and figured that I would put it on later... now I can't see how it would be possible to install with the radiator in! Is it possible? I have a flex fan and it's about 2" from the radiator, while the shroud is about 6" deep.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-20-2010, 02:34 PM   #2
junkyardjohn
junkyardjohn's Avatar
Re: Can't get my fan shroud on...
YOU HAVE TO PULL THE FAN ASSY. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-20-2010, 02:55 PM   #3
johnechi
johnechi's Avatar
Yup, like John said. Pull the fan/fan clutch assembly from the water pump pulley (assuming you've loosened the alternator belt) Put the fan shroud onto the radiator loosely, then mount the fan/fan clutch assembly back onto the water pump pulley. Its a little tight getting the bolts back on but doable. Then readjust and tighten alternator belt and tighten screws on fan shroud.
johnechi is offline   Reply With Quote
Old 05-20-2010, 03:58 PM   #4
mdwilf
mdwilf's Avatar
I may be wrong, but I think your fan may to too close to the radiator. It's supposed to be hanging out the back (eng side) of the shroud to be it's most efficient.
What I do in my spare time:
http://rosebudsgarage.shutterfly.com
mdwilf is offline   Reply With Quote
Old 05-20-2010, 04:01 PM   #5
crakarjax
crakarjax's Avatar
You could be right, its a flex fan so apparently not stock. There is a spacer between the fan and the water pump; I wonder if I can get a new spacer and bolts? In any case, does it really matter? I did notice that my temps are around the cold side of the stock temp gauge but that's with the shroud off... It might make matters worse when I shroud it. Thanks for the tips guys, it was unclear how I would bolt the fan back on afterinstalling the shroud but it's pretty clear now.
Old 05-20-2010, 05:19 PM   #6
mclairmo
Fan blades should be half way in and half way out of the shroud for best efficiency and as close to the edge of the shroud as possible without rubbing. However, if the engine kept cool as is, then it clearly is not critical in your case.
mclairmo is offline   Reply With Quote
