Old 05-20-2010, 07:07 PM   #1
irish1966
irish1966's Avatar
What exhaust setup have you got??
I am at the point where I am going to start setting up the exhaust on my 66 LWB Fleetside project. I am trying to figure out the best route and sounding setup. I understand that it is a preference, but any inputs would be greatly appreciated. Here's what I have to start with....
I am putting in a rear mount gas tank also, so any problems or recommendations would be great.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 05-20-2010, 07:46 PM   #2
lakeroadster
Re: What exhaust setup have you got??
i too have a rear mount tank. I have header mounted glass packs and will be running the tail pipes back to the trailing arms and then outside the frame rails, exiting at the rear of the truck.
lakeroadster is offline   Reply With Quote
Old 05-20-2010, 07:51 PM   #3
irish1966
irish1966's Avatar
Any pics of the setups would be great. My buddy keeps saying how it should go, but I'm not convinced. Also, where do i get the header pipes from the rams horns down to the new exhaust?
Cheers
David
Old 05-21-2010, 10:50 AM   #4
Oklahoma
I have Ram horns with a Y pipe to the driver side with a turbo muffler, then it kicks out behind the tire adn I think it sounds great.
Oklahoma is offline   Reply With Quote
Old 05-21-2010, 11:14 AM   #5
irish1966
irish1966's Avatar
That does sound sweet Oklahoma!! I'm thinking maybe dual out the back with a roll pan.
Cheers
David
Old 05-21-2010, 10:24 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a few shots of mine. I’m running the same rams horn manifold you are – straight down on the passenger side and canted on the driver side. Custom 2 ½” pipes with Flowtech Terminator mufflers mounted vertically under the bed, ending in turn downs just ahead of the axle. Best I can describe it sounds like a 1960’s Corvette, aggressive and powerful, yet relatively quiet. There is no droning in the cab. Earlier I ran the same setup without the crossover pipe, and it really barked when the throttle was cracked. The crossover muted the full throttle bark a lot.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-21-2010, 11:03 PM   #7
irish1966
irish1966's Avatar
Looks excellent man. Any reason why you stopped at the diff? And do u have a rear mount tank?
Cheers
David
Old 05-21-2010, 11:17 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Personal preference was all, I just like it with turn downs. I thought about going out in front of the rear tires, but I've had cars with that arrangement and it's really hard on aluminum rear wheels. I didn't want full tailpipes because of the rear mounted tank, and didn't want interference if it needed to be removed. So yes, I do have a custom 33 gallon Rock Valley tank mounted behind the axle. At the time I designed the tank this was a long distance freeway commuter. Having lived through the gas shortage period of the 70's, I wanted the biggest capacity I could fit in the space available (limited trips to the pump). It tucks up nicely, but if I had it to do over, I'd go for something closer to 20 gallons. Now that I'm retired it takes a long time to use up a full tank of gas. Here's a shot of how well the tank fits, so full tailpipes would have fit okay:
Old 05-22-2010, 12:02 AM   #9
irish1966
irish1966's Avatar
Thx Markeb01. U answered my question perfectly. I really like your setup. I'm strongly considering the same idea.
Cheers
David
Old 05-22-2010, 08:50 AM   #10
pharmd
pharmd's Avatar
Full Length headers, true duals, H pipe, 3 chamber flowmasters, turn downs near the rear.
Not the absolute setup for power, but one of the best sounding setups I have hear (but then again, I'm biased).
pharmd is offline   Reply With Quote
