Old 05-20-2010, 07:38 PM   #1
project1968
project1968's Avatar
Western Drop Spindles
I got some Western spindles for a good deal today..Are they the same as CCP about using 71-87 brake components?
project1968 is offline   Reply With Quote
Old 05-20-2010, 07:47 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Western Drop Spindles
I'm not sure I understand what you are asking.
What year spindles did you buy?
63-70?
71-72?
73-87?
Keith
Convert to disc brakes.
Old 05-20-2010, 09:04 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
yes 71 -87 work but if you want to keep your 6 lugger than use a 92 2500 ( under 7300 GVW) disc..it all bolts on but you will need the covertion adjuster from CPP to adapt the pre 71 center link to the newer tie rod end
Im doing the same thing..took alot of homeowrk to find this out
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-20-2010, 10:25 PM   #4
KMACD71
KMACD71's Avatar
Western spindles are the spindles that you get from CPP. At least that's what I got with my kit. There are differences depending on year.
KMACD71 is offline   Reply With Quote
Old 05-20-2010, 10:38 PM   #5
leddzepp
Moderator
leddzepp's Avatar
If you got Western spindles from CPP, they are the 71-72 type. The other years they sell are their own brand (stamped with CPP logo). I have them on my SWB truck and they fit like a glove, zero issues.
To answer your question, yes 71-87 disc brake stuff works, and you will need 71-72 ball joints and tie-rod ends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-20-2010, 11:35 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
My 73-87 drop spindles I got from CPP were made by Western & I think they're junk
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-20-2010, 11:42 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Why is that?
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-21-2010, 08:45 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My CPP 73-87 spindles are Western brand too. Straight out of the CPP box...
Old 05-21-2010, 09:10 AM   #9
Hottrucks
Hottrucks's Avatar
hey Tex ,
what rubber line did you use to your calipers??and what adjuster it looks like a stock part??
one thing I have learned is to buy just the spindles and tie rod adjusters.....the rest of the parts you can usually get locally..this saves a ton in shipping.....my thought was if something ever happens to a disc like it warped or something do I have to go back to my vender to get the disc...these spindle makers don't make the discs,calipers or pads,they use off the shelf parts then re$ell them to us...a good parts man wll find out what it is...like I said for the 6 lug pattern the 1992 chevy 2500 ( under 7300lbs) discs are the ticket about $60 at Napa (and no shipping) it also cure the use of modern wheels up front but I'm not sure about how they fit on the rear axle since I'm using stock 6 lug rallies all the way around
Old 05-21-2010, 09:59 AM   #10
SCOTI
SCOTI's Avatar
Originally Posted by Hottrucks View Post
hey Tex ,
I seem to recall 6-lug 88-98 rotors don't fit 71-87 spindles. The same swap can be done using 88-98 spindles though.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-21-2010, 10:11 AM   #11
Tx Firefighter
Hotrucks, every single inch of brake lines on my truck are unaltered stock 80 model stuff. It's all 100 percent bolt on from the master
cylinder to the wheels. The hoses are
braided stock 73-87 hoses from Summit,
Russell brand.
Old 05-21-2010, 10:20 AM   #12
Hottrucks
Hottrucks's Avatar
thanx Tex..what about the tie rod adjuster??
Scotti I brought my spindles (western) and 5 lug discs that came with it to Napa (Lee) he took all the measurements and came up with the 92 2500 under 7300lbs ( keep in mind the 3/4 ton model is diff than the others) he grabbed one off the shelf and we slid it on...sized it up every which way..it was exactly the same except it was 6 lug
Old 05-22-2010, 03:05 AM   #13
leddzepp
Moderator
leddzepp's Avatar
When I bought mine at the counter all of the other years were CPP brand. The only Westerns they had then were the 71-72. I guess they sell whatever they have at the time. Have you ever had a problem with yours? Mine fit great and I drive the truck daily.
OP- I would take one of the spindles to a parts house and check to see which year tie rod ends/ball joints fit.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-22-2010, 07:44 AM   #14
Hottrucks
Hottrucks's Avatar
I beleive 73-87 tie rods and ball joints
Old 05-22-2010, 09:32 AM   #15
SCOTI
SCOTI's Avatar
That's the first I've heard of the direct swap capability. It's good to have a parts guy that investigates possibilities.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-22-2010, 09:45 AM   #16
project1968
Thanks for all the responses, now all I need is time to work on the truck. I work for Budweiser in Nashville and we lost our building and a half a million cases of beer in the flood we had here a couple of weeks ago , so we have been working around the clock to get back to normal.
Spraybomb, why didnt you like your spindles?
Old 05-22-2010, 08:12 PM   #17
baclay9
Sorry but what is CPP?
baclay9 is offline   Reply With Quote
Old 05-22-2010, 09:18 PM   #18
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
hey project1968 where did you get your spindles...i saw some western boxes at goodguys today shoulda asked about em..
John
1999 Toyota Tacoma 4x4
Old 05-22-2010, 10:41 PM   #19
project1968
I got them from a friend at work..I was at Goodguys today. I wish I would have saw them. How much were they selling for?
Old 05-22-2010, 11:05 PM   #20
oldblue1968chevy
I dunno I just saw the boxes..i didnt need to spend more money lol....it was towards the stadium on one of those rows..if that helps go back tomorow your close!
John
Old 05-22-2010, 11:08 PM   #21
HarrolLS1
HarrolLS1's Avatar
Classic Performance Products http://www.classicperform.com/
Harrol
1968 SWB
1968 SWB 4x4
1969 Suburban
1970 LWB
1970 Blazer
2002 Tahoe
Inside every older person is a younger person wondering what happened
HarrolLS1 is offline   Reply With Quote
Old 05-23-2010, 11:12 AM   #22
crakarjax
crakarjax's Avatar
I hope that beer floated right into your garage!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-23-2010, 03:07 PM   #23
seafoam68
seafoam68's Avatar
Angry Re: Western Drop Spindles
Wow, that explains some things. I got my drop spindles from CPP and they were Western. They were supposed to use 73-87 rotors, which I purchased local from Napa. However, the rotors don't seem to fit right. Maybe they are supposed to be early model ? had a really hard time with tie rod ends also. Even called CPP to inquire if I had the right spindles and was told yes. Hmmmm...
seafoam68 is offline   Reply With Quote
Old 05-23-2010, 08:22 PM   #24
Hottrucks
Hottrucks's Avatar
sea foam if your staying 6 lug you need the 92 2500 disc but it needs to be the under 7300lb version..
but I thoght the tie rods where 73/87..what did you find??
Old 05-23-2010, 09:03 PM   #25
oldblue1968chevy
Wait, so your saying I can mount a mid 90's 6 lug spindle on a 71 rotor??
John
