Old 05-21-2010, 10:59 AM   #1
blazer2007
how often do u drain tank?
Just wondering how often to drain tank and will it ever get into the bags and do damage.I made a mistake and my drain valve is really hard to get at.
blazer2007 is offline   Reply With Quote
Old 05-21-2010, 11:54 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: how often do u drain tank?
as often as I remember but at least once a month ussually more..it would take alot to get to your bag outlets and since it takes up space in the tank your compressor needs to run more often
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-21-2010, 03:06 PM   #3
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
How does water taking up room in your tank make you compressors run longer?
And I drain mine whenever I can/remember. Probably about twice a month.
AVS_JASON is offline   Reply With Quote
Old 05-21-2010, 04:30 PM   #4
Hottrucks
Hottrucks's Avatar
let exagerate the amount..if you have 1 gallon of water in a 3 gallon tank you only have 2 gallons of compressed air not the 3 you should....the presure will be the same but there will be less volume of it...think of it as have 5 tanks you could go up and down 10 times if you have 1 tank you can get maybe 2....volume is the key thats why you seem some kids running compressed O2 in the big cylinders...VOLUME....
Old 05-21-2010, 06:05 PM   #5
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
I see what you meant. When I read it the first time I thought you were saying that the comp would work harder filling the 3 gallon tank with 1 gallon of water in it, then the water free 3 gallon tank.
Old 05-21-2010, 09:41 PM   #6
kev2809
low n' slo
kev2809's Avatar
is a tank drain a must?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-21-2010, 10:48 PM   #7
Hottrucks
Hottrucks's Avatar
Good because it made sence in my head..but sometimes to try to put into words is tough
Old 05-23-2010, 11:37 PM   #8
texastrendz
Never have to drain mine
texastrendz is offline   Reply With Quote
