Old 05-21-2010, 03:30 PM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
Rear end width
I searched on here and did not find what I was looking for.
I would like to know the width of the factory rear end, WMS to WMS for a 64-66 1/2 ton.
What other years are also that width? Lug pattern does not matter to me at this point...
Any one else know what other rear ends might be similar in width?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-21-2010, 03:43 PM   #2
SCOTI
SCOTI's Avatar
Re: Rear end width
I measured the rear housing for my 68 not too long ago while investigating swap candidates. It should be the same as the 64-66 housing which is the narrower housing vs. 71-87's. It was 62" (WMS to WMS).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-22-2010, 12:10 AM   #3
Captainfab
60-66 Nut
Re: Rear end width
The '63 to early '70 rear differentials measure 62" WMS to WMS. The last one I measured was actually 62 1/8", so there is a little varience.
Old 05-22-2010, 11:04 PM   #4
aggie91
aggie91's Avatar
Re: Rear end width
Thank guys, I knew that someone would have the info that I need.
If I look for a 63-70 rear end for a bolt in, any would work correct? I plan on doing the pan hard mount on the PS trailing arm so the housing mount does not really matter...
Karl
The LST Challenge:
Old 05-22-2010, 11:16 PM   #5
Captainfab
60-66 Nut
Re: Rear end width
For the most part yes. The '63 12 bolts had pressed on backing plates, so depending on just what you're doing that may or may not be an issue. The '63 & '64 12 bolts had the panhard bar mount on the passenger side axle tube, but as you say that doesn't matter to you. I just thought I'd mention it for the benefit of others reading this. Be careful when looking at a '70 12 bolt as this was the transition year for the widths. As I understand it, the early '70 model year differentials were the narrower and the later in the model year they were 1.5" wider, as the '71-'87 rear differentials.
Old 05-22-2010, 11:29 PM   #6
aggie91
aggie91's Avatar
Re: Rear end width
Thanks, Captain. I am going to look at other rear ends also. My current 9" is 56" wide and I don't feel like running super wide tires this time and I don't think that 3" spacers on each side is a good idea either...
Karl
The LST Challenge:
Old 05-23-2010, 11:07 AM   #7
crakarjax
crakarjax's Avatar
Re: Rear end width
Out of curiosity, is there a benefit to the wider or narrower track width?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-24-2010, 01:20 PM   #8
aggie91
aggie91's Avatar
Re: Rear end width
I have changed direction with this truck and looking to go back to the stock rear end width and use a narrower tire on a 8" rim as opposed to a wider tire on a 12" rim...To me a wider track would be more stable.
Karl
The LST Challenge:
Old 05-24-2010, 02:12 PM   #9
SCOTI
SCOTI's Avatar
Re: Rear end width
It comes down to back spacing preference as the change in width between the years (6x-70 vs. 71-87) is minimal (1.5" total). If you like more wheel lip, the narrower width is preferable.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-24-2010, 02:18 PM   #10
michael bustamante
michael bustamante's Avatar
Re: Rear end width
when switching to disc brakes it pops the front tires out more than the rear end does so people like to swap to the 71-72 rear end for that purpose, also to convert to 5 lug. I have a 70 rear end on my trailer with leafs and it is the wider rear end with 6 lug axles
1967custom
michael bustamante is offline   Reply With Quote
Old 05-24-2010, 03:05 PM   #11
aggie91
aggie91's Avatar
Re: Rear end width
I agree, but I may end up with something other than stock to get the stance/look I am after with the wheels that I have. I might even have to order "new" custom steel wheels...I like a wider wheel lip on the rear too.
Karl
The LST Challenge:
