Old 05-21-2010, 03:47 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Question about 2-1/2 ton axles
I came across a guy that has an old military truck, 6 wheel drive that he's willing to sell. It runs but the tranny is busted he says. I have no use for the truck or even the axles.
What would the axles be worth on something like this? Seems like the serious off roaders are looking for them, but I don't really have the room to keep something like this around waiting months for the large parts to sell.
Is there any particular things I should be looking for on this truck to know if it's even worth the trouble?
hgs_notes is offline   Reply With Quote
Old 05-21-2010, 03:58 PM   #2
JimmyFloyd
Re: Question about 2-1/2 ton axles
Try Pirate4x4 or ColoradoK5. They have more serious offroaders, and those get sold fairly often, so you can see what they go for.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-21-2010, 04:01 PM   #3
Jason M
I have a pair of steering axle's that I narrowed for a buggy podject, well that on hold for now. But one thing I would check is year of the truck, that will tell if it has the U-joint style shafts or the older bendix style shafts. Unless of course some one swapped the shafts at one time or the other.
Best thing to do is to cut the boot around the knuckle and feel for a U-joint cap.
A steering axle sells for 800-1K, rears sell for 300-400 hundred, guys normally run them till they find another steering axle since the factory turning radius stinks and most are welded front and rear. Or they get a rear for the extra chunk or 3rd.
Some of the 2.5 ton T-case's are air shifted and alot of the mudding guys like them better.
Jason.
Jason M is offline   Reply With Quote
Old 05-21-2010, 05:19 PM   #4
Mudder
Mudder's Avatar
For the really serious offroaders!!!!! Those things are tuff if you are going with huge tires and lots of HP. Removing the brake drums and installing drive line brakes are the way to go.
Mudder is offline   Reply With Quote
Old 05-21-2010, 05:31 PM   #5
Psycho 86
King Monkey Nut
Psycho 86's Avatar
Jason is dead on about prices for those axles !! Plus the 2.5 cases are in demand !! Just post em up on any mud website (there are tons ) you will certainly get some offers if priced right !!
Fear me for I am the keeper of nuts, the soldier of Monkeyness, I strike down those who try to oppose theKING MONKEY NUT!!
THROTTLE KING QUALIFIER This Yankee is gonna show them Rebels how the North muds !!
Psycho 86 is offline   Reply With Quote
Old 05-21-2010, 07:54 PM   #6
Jason M
A little off topic but here's some Pics of how I narrowed my set of steering axle's.
I took 7.5"s off the long side to run a short side shafts in each axle.
Made a line up pucks to fit the carrier jurnals and a another set to match the machined surrface on the end were the outer seals sit.
I then cut the housing and chopped 7.5'' off the long side.
In stalled the line up bar. Beveled one side and installed back up strips and welded them 100% and left the cover caps for a little extra beef.
Jason.
Old 05-22-2010, 12:06 AM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Just curious on this, and sorry to the op of this thread, but are the 5 ton's worth anything? Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-22-2010, 12:42 AM   #8
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks for the input on this everyone. Seems like all the pictures of rockwells I see show square tubes from the diff, while these are round tubes. I'm not even sure how to identify what this beast has on it.
Old 05-22-2010, 01:24 AM   #9
71blksuper4x4
SWB 4x4 Collector
It isn't a m715 is it? Trevor
TREVOR
Old 05-22-2010, 07:28 AM   #10
Jason M
Round tube is an early GM version and really not worth anything to the off road croud. The are a weeker axle than the square tube style and the front axle needs a T-case that spins backwards unless you flip the 3rd memeber over.
Jason.
Old 05-22-2010, 07:57 AM   #11
msgross
msgross's Avatar
make it into a Bobbed Deuce...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
