Old 05-21-2010, 07:51 PM   #1
remist17
remist17's Avatar
87 stepside
hi all.
I am looking at a 87 step tomorrow, it has a 6 cyl auto. What tran would be in it?
Is it still carb? If I wanted to put a 383 in it carb, how hard would that be? I would think the motor mounts would need changed?
Any help is appreciated
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 05-21-2010, 08:05 PM   #2
D13
D13's Avatar
Re: 87 stepside
If it's still stock an 87 would be 4.3 V6 wtih throttle body fuel injection, 700R4 auto overdrive. Converting to carb takes a fuel regulator, motor should drop right in, but the trans should be upgraded too!
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-21-2010, 08:09 PM   #3
remist17
remist17's Avatar
Re: 87 stepside
I would put in a built 700 to go w the 383. how hard would it be to change motor mounts?
assuming from above post, this is a tbi?
Support the Troops.
Old 05-22-2010, 06:20 PM   #4
remist17
remist17's Avatar
Re: 87 stepside
OK all I got the truck. IT has a 6 cyl and 700r4 tran. The truck is in pretty good shape except the bed. Questions:
1- The above question on motor swap
2- Radiator seems small so I need to put a larger radiator in
3- good vender to get bed parts and other parts.
Support the Troops.
Old 05-23-2010, 09:05 AM   #5
remist17
remist17's Avatar
Re: 87 stepside
bump
Support the Troops.
Old 05-24-2010, 09:57 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 87 stepside
The engine mounts and frame stands will swap right out. You can probably find the stands from one of the several guys parting out 73-87 trucks that had a 350 pretty cheap. I also imagine the radiator will definately need upgraded like you were saying. Any pics of your truck?
--Josh
Old 05-25-2010, 09:11 AM   #7
tgh117
Crazy
tgh117's Avatar
Re: 87 stepside
I just bought a bunch of bed parts for my truck resto about a year ago from LMC truck. The inner bedsides, which I am betting you need being a PA truck are top notch. All hand made and excellent quality. There fenders were the same chinese stuff you can get anywhere else, so I would probably try and find some used ones somewhere if you can for that. Not sure what else you need but there are many places to find the stepper parts. Just need to hunt for them a bit.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 05-25-2010, 01:01 PM   #8
remist17
remist17's Avatar
Re: 87 stepside
I am going to try and price the body parts local to save on freight. I am thinking about replacing the drivers door. Its a little rusty but not bad. I am planning to put a 383 stroker and either a 350 tran or 700R4. Trying to decide. If anyone can help me out with some photos of wheels. I really would appreciate that. I am trying to fill the fenders. No drop yet.
Support the Troops.
