misshape grape
proper rear spring perch placement on a shortbed?
the previous to previous owner moved the perch up, and now we're thinking back as well?
![]() ![]() ![]() ![]() ![]() does anybody have pictures of a non modified, or frame dimensions from perch to back of frame? thanks!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
misshape grape
Re: proper rear spring perch placement on a shortbed?
we think it was not only moved up, but back as well. new aftermarket replacement leaf springs are shorter. the perch is too close to back of fram on a 83 c10 swb, right?
correct location should be where the further forward holes are where there is currently a zip tie
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. Last edited by pat386; 05-21-2010 at 10:38 PM. |
yeller
Looks factory to me. There were two different spring sizes, with the heavier duty one being the longer one, thus having your rear spring hanger further back on the frame. I am assuming your original springs were a 7-8 spring pack?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
misshape grape
Thanks for the reply. I have photos of when the guy did a restoration of it in 93 or so, and the pics show different leaf mounts on the frame during rebuild, to today. the truck has an RPO code of 1g51, being G51 - Rear Extra Capacity Springs, and another site lists it as G51 : SPRING REAR, HEAVY DUTY, VAR 2. So I am stuck now...I can't tell if these mounts are for heavy duty, or non heavy duty. measuring my leafs on the truck from center of hole straight across to center of hole it is roughly 53.5". The aftermarket 'non heavy duty' springs are 49" measured the same way.
I guess it is off to the junkyard tomorrow to find a heavy duty leaf spring pack. thanks for the reply! just trying to level the truck out with a flip kit in the rear, and it's just a tad bit bigger of a dilema than i thought!!
yeller
Those are for HD leafs. The hangers are the same part number no matter what spring you have, it is just the location that changes based on the spring the truck has.
#6 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
