house of chevy's
dead truck?
so i drove my truck to my buddys house today went to drive it home and its dead tryed to jump it but bat still has power my lights work horn ect but no starter noise or radio i installed a new battery guage and a oil pressure guage yesterday but it ran fine this morning any help would be great need to figure it out quick
Re: dead truck?
Have you checked for a blown fuse?
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
Re: dead truck?
also check for a blown fuseable link near the starter.....
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
house of chevy's
Re: dead truck?
i did look at the fuse panel quick last night it was dark not going to be able to really look at it till tommarrow as i have a party today would the neutral saftey switch have any thing to do with it if you can think of any thing else it would be great
![]() Join Date: Jun 2007
Re: dead truck?
Where do you have your radio getting its power from? Is it stock or have you wired it in somewhere else? Shouldnt be too hard tracing back a common point for the starter and radio.
Re: dead truck?
This happened to me in December. The truck shorted out and the fusible link was blown. the truck did not have any dash light and the ignition wouldn't even try to start. Everything wired always hot worked though. The fusible link is the black piece on the red wire leading to the rubber piece mounted on the firewall to the left of the master cylinder. They can be bought at auto zone don't by and inline fuse they blow to easily.(60 amp fusible link should do)
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Re: dead truck?
goldfinger is putting you in the the right place but my problem was the red wire..... came back home and had no power what so ever anywhere had to replace the i lombe...... if you look at my pic the black wire behind the red one is the fuse link hes talking about...............
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
Re: dead truck?
if you have a good light tester check the fuse link on both sides more and likely thats your problem
Re: dead truck?
Mine had a different type of link. thanks for the correction.
Re: dead truck?
thats what 73's look like don't know what the newer models look like i just figured a picture speaks louder then words lol
house of chevy's
Re: dead truck?
thanks ill have to check that out
Parts and more parts
Re: dead truck?
There is a fusable limk near the brake booster that can fry. If it is gone, then the truck will not start or run. I carry a couple spares that I cut off of old trucks in the junkyard with me.
Frank |
#13 |
house of chevy's
Re: dead truck?
were can i buy one and what should i ask for just a fusable link
#14 |
Re: dead truck?
auto-zone, OReilly, advanced. just ask for a 60 amp fusible link. DO NOT buy an inline fuse. the fuses will blow and you will be left stranded.
#15 |
house of chevy's
Re: dead truck?
just got home that is what it was thanx for all the help guys
#16 |
Re: dead truck?
It helps when you know what the problem is so your not so worried the second time around.
#17 |
Re: dead truck?
anytime this place has helped me more than once...... just figured i give some feed back
#18 |
house of chevy's
Re: dead truck?
another ? what is the point of the black thing the wires a bolted to couldnt they just be connected?
#19 |
Re: dead truck?
just the way they did s*%@........... theres a reason for it but I could not tell you..... every manufacter has a weird way of doing things............. like ford for instance why put the silaniod on the fender why not put it where chevy did on the starter see what i mean lol........
#20 |
Re: dead truck?
I think it aids insulation and it was a place a person could find it. As much as i hate to say it i love the ford solenoid position.
#21 |
house of chevy's
Re: dead truck?
ya doesnt make sense to me but i fixed the prob my girlfriend thought it was funny she said my truck was mad at me for driving my buddys ford all day lol
#22 |
Re: dead truck?
hahahahaha @ ur truck getting mad @ u
| Bookmarks |
