Old 05-22-2010, 11:20 AM   #1
thegoot
lug pattern HELP!!!!!!
What is the easiest way for me to change my 5x5 bolt pattern on my 68 to a smaller 4 3/4 pattern off of a camaro or chevelle? Do they make an adapter or is there another way? PLEASE HELP
thegoot is offline   Reply With Quote
Old 05-22-2010, 11:26 AM   #2
SCOTI
SCOTI's Avatar
Re: lug pattern HELP!!!!!!
If your 68 is 5x5, it's been updated as they're originally 6-lug. Assuming it's a typical disc swap using HD 1.25" rotors, Perf On-Line sells a direct swap car pattern rotor for the disc brake truck spindles. Lt.duty set-ups can use Camaro '1Le' option front rotors (12" rotors w/a car pattern that use different bearings vs truck rotors).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-23-2010, 07:23 AM   #3
OARNGESI
OARNGESI's Avatar
You can buy billet adapters off of ebay for like 60 for 2
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-24-2010, 12:32 AM   #4
Captainfab
60-66 Nut
I've read in another thread here that the rotor from a '72 Impala will fit the truck disc spindles, and they are 5 x 4.75"
