Carb. placement questions
I scored a rebuilt Rochester for my pick up but I'm having issues with the fuel line hitting what I think is the Egr Valve(it comes out of the water neck)? I was wondering if maybe someone has run into this problem before and what they did to fix it. Pictures would be great. The carb I have on it right now, the fuel line come from the side. I hope I explained it good enough. Please help. Thanks
Re: Carb. placement questions
could you upload a pick?
but it almost sounds like you have a ford qjet?.. i'd just bend the line so it doesn't hit anyhting.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
The one I have on there now is similar to this with the fuel spout coming out toward the left.....
http://www.streetperformance.com/ART...-Quadrajet.jpg The one I would like to put on is like this with the spout coming out straight... http://carb-shop.net/images/IMG_3139.JPG Of course I don't think either of those carbs are mine. I quess mine is electric. Any ideas? Thanks Last edited by CenValyCali; 05-22-2010 at 02:11 PM. |
No one?
the second on you posted is a ford carb... as for the electric?... no idea, never seen one
I'd just go rebuild a holley and slap it on...
Cruzzzn' Vet
your egr valve is that little flying saucer looking thing behind your choke.. what your describing sounds like a vacuum tree on the gooseneck
"I'll keep my guns, money, and freedom. You can keep the "change" |
![]() Join Date: Jul 2003
The picture of the second carb I know 100% is the quadrajet style used on Oldsmobiles.
So, you got the BOP version (with front fuel inlet) and you needed the chevy version(with side fuel inlet).
The obstruction is most likely a thermal vacuum switch on top of the water neck---will check my setup soon. It would probably be best to post a picture. Re-working of the fuel lines may be nessesary. |
