05-22-2010, 02:01 PM | #1 |
Loose steering wheel
Can anyone tell me how to tighten up my steering wheel on my 74 c10. It was missing the lock plate but now i just put it all back together and its still loose.
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS |
05-22-2010, 02:23 PM | #2 |
Re: Loose steering wheel
Is it a tilt wheel? Is the column loose or just the steering wheel?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
05-22-2010, 02:24 PM | #3 |
It is tilt. Its just the steering wheel thats loose
05-22-2010, 02:26 PM | #4 |
I would bet its the large keeper nut down deep inside the column that keeps a bearing tight, they are bad to back off and they are a pita to get to and tighten.
05-22-2010, 02:30 PM | #5 |
Thats exactly where i thought it was coming from. Because if i move the wheel in the right spot and push it in it feels like its suppose to and if i pull it put its loose again. So how do i tighten it.
05-22-2010, 03:00 PM | #6 |
I done mine about 12 yrs ago I cant walk you thru it but after you remove the wheel, theres a keeper ring on the steering stem and If memory is correct its under the turn signal cam.
05-22-2010, 04:50 PM | #7 |
Ok. Its the steering stem that is loose. It wasnt like that until i removed the steering wheel and after i put it back together i couldnt get it to tighten back up.
72 SIERRA LB 74 C10 SB 85 C10 SB 75 EL CAMINO SS Last edited by po_bird; 05-22-2010 at 04:59 PM. |
05-26-2010, 11:48 AM | #8 |
'59 pache
check out this article in super chevy mag
http://www.superchevy.com/tech/sucp_...umn/index.html |
05-26-2010, 03:48 PM | #9 |
There's a really good video on Youtube. The guy is working on a Camaro and it's the same exact process for our trucks. You need three special tools. I don't have the link but if you search, you'll find it. Oh, make sure to locktight the screws like he says. I didn't and it came loos in a few weeks.
California Shloopter '87 fleetside shortbed, 5-7 drop, stock engine '66 VW Beetle, on the ground '57 VW Manx copy, work in progress |
05-26-2010, 04:09 PM | #10 | |
I really hate wet sanding!
If the entire tilting part of the column is loose, you will have to dig a little deeper to get to the loose bolts and it wil require another tool, tilt column pin puller tool. Regardless, you need the locking plate and if you pick up even all three of the mentioned tools, they won't set you back about $30-40. Hope this helps, good luck.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
05-26-2010, 08:10 PM | #11 |
Still plays with trucks
Some have a flat washer under the retaining nut holding the steering wheel in place and some don't. There are not enough threads on there to tighten down the nut without the washer in some cases. I found this out the hard way on a car I was working on when I left off the flat washer.
Since you just had it apart it is possible you left off the flat washer if yours had one. Make sure the nut is tight against the steering wheel and the wheel doesn't move in & out from under the nut when you push on it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
