![]() Join Date: May 2010
1984 c10 crossmemeber into 1963 c10
Hi all, I'm new to this site and I've seen lots of cool stuff on my visits! Its nice to see so many folks that share the love of 60-66 C10's.....
Does anyone know if the complete crossmember out of an 1984 C10 will bolt directly into a 1963 C10? both are 1/2 ton 2wd. I would appreciate any and all feed back. Thanks............. Denehttp://67-72chevytrucks.com/vboard/images/smilies/gmc2.gif |
Re: 1984 c10 crossmemeber into 1963 c10
Dene,
There is a great write up on the site somewhere which breaks down the newer year models front k-members which bolt into our older trucks. If I remember correctly yours should darn near bolt right in. Youll have to elongate some bolt holes but very minimal work is required when doing this swap. I have a 1966 which I put a 87 c-10 front end on. I had to elongate some bolt holes but that was it. Actually I drilled out all the holes and purchased some nice beefy grade 8 bolts from Tractor Supply and replaced them all. It was pretty simple. |
#3 | |
Thank you for the info, I will continue to check throughout the site...... Dene
60-66 Nut
![]() ![]() Join Date: Mar 2007
Here is a thread in the FAQ's that covers most everything you'll need to know. All the front suspension crossmembers from '63-'87 trucks, and Suburbans from '63-'91 interchange quite easily.
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
Thanks Captain Fab, I will check it out!
By the way, been to Idaho several times, loved every bit of it! Take care ........ Dene |
