Old 05-23-2010, 10:53 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Big Brakes from GM....
With all the talk about big brakes got me thinking what "late model" GM cars/trucks cae with usable brakes. I know they won't just bolt on, but what are some good candidates for conversion material?
I was at my local tire shop yesterday and happened to see the brakes on a new H3. The size of the front caliper got my attention. It is a large 4 piston caliper on the front, and a nice looking single piston caliper with E-brake on the rear.
Hmmm, any thoughts?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-23-2010, 11:05 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Big Brakes from GM....
I like the way you are thinking ...but did tey ever make a 2 wheeld drive?? seems you could pull the axle and use it as a hub?? then you could rape the spindle and give it to a good parts guy to find the parts to make it work??...sounds pricey though
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-23-2010, 02:42 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Using 6 lug rotors on a 5 lug axle will be an expensive swap. You can't lay down a 5x5 pattern on the6 lug without going into another hole... You would have to weld up the other holes and start over... Now if you had a rotor that has similar thickness and od it could work with custom brackets
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-23-2010, 03:53 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
They did make the H3 in a 2wd, but I'm pretty sure it was 6 lug as well. Clint has done the leg work already to verify that the 6 lug rotors won't work. I do think the calipers might be of interest though. I'll try to dig deeper and find specs on them.
I was just surprised when I saw this as to how big that front caliper is. It appears to be larger than the one on my 09 Sierra.
Articles-
"Refining Sierra"
Old 05-24-2010, 12:42 AM   #5
Captainfab
60-66 Nut
I've done a bit of searching for OEM big brakes as well. Most of what I've found have been 6 x 5.5" wheel pattern. For those of us with 6 x 5.5" already that isn't a problem. The issue that I haven't figured out is an economical 6 x 5.5 hub for the front so as to utilize the bigger rotors on the front.
Old 05-24-2010, 03:16 PM   #6
aggie91
I'm just glad to be here!
aggie91's Avatar
Why not use the factory 6 lug hub and spindle from the drum brakes and fab a custom bracket to bolt to the spindle? I now that would not help those wanting the 5x5 pattern, but it is a start??
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-24-2010, 03:58 PM   #7
Hottrucks
Hottrucks's Avatar
have you found a 6 x 5.5 rotor?? tracing it backwards should be easy....most stock spindles ( from what ever you find the big 6 on) should convert to our A arms??
as far as geting the 5x5 thats easy...most 1/2 ton truck rotors will fit..just need a good parts guy to check the diameter thickness and height...all that info is available IF you can get them to look it up in a BOOK ...my parts guy kinda digs these one off projects..I drop stuff off tell him what I want to do and tell him to call me...if you want it NOW he'll tell you where to put it...he ussually calls in a couple days if nothing else to tell me to stop being a cheap...... and come get my crap..some stuff is just aftermarket
Old 05-25-2010, 06:58 PM   #8
Jonboy
Slots go on anything!
Isn't the H3 on a Trailblazer frame? The rear brakes look suspiciously like 99-up Silverado rear disc brakes, very similar. Not sure about the fronts, though.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-25-2010, 07:19 PM   #9
SCOTI
SCOTI's Avatar
Yes, the H3 is a 'cloaked' Trailblazer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
