05-23-2010, 04:14 PM | #1 |
Tilt column help?
After taking a 1977 chevy van column apart and powdercoating the exterior and doing the neutral safety switch mods I rebuilt and installed it into my truck with no problems. My problem is that my shifter doesn't have any distinct gear positions. It just feels like the shifter is very smooth through the pattern instead of having a position for each gear. Any tips on whats going on in the column that I can fix?
"The Ultimate Sleeper" 69' SWB, Holley EFI 525 ci. BB, TH350, 3.73 Eaton posi/Moser axles, 1350 diveshaft, Vintec's 20"x8.5" and 20"x12", OPP windows, CPP rear coilover conversion |
05-23-2010, 06:39 PM | #2 |
member #16
Re: Tilt column help?
Do you have the shift plate and lever spring installed correctly?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-23-2010, 10:06 PM | #3 |
Not sure but, it will be the first place I check. Do you have to remove the column from the truck to get to that part of the assembly? It has been so long since I had it out I cant remember.
05-23-2010, 10:43 PM | #4 |
Learned something new. I thought it was the transmission that gave it that clicky feel.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-23-2010, 10:47 PM | #5 |
I'm pretty sure its a little of both.
