Old 05-23-2010, 06:21 PM   #1
guardmp
Question Stuck float?
I've got a 72' GMC Truck I'm working on with the standard Edelbrock carb on it. I think the float is stuck, but I'm not sure. I know where to look for fuel dumping out on a Holley, but my Edelbrock experience is very(very) limited. When a float sticks on an Edelbrock and the needle stays open, where does it dump fuel? Also how do you free the float? Thanks for the info.
guardmp is offline   Reply With Quote
Old 05-23-2010, 06:44 PM   #2
'72customdeluxe
Re: Stuck float?
Mine just flowed out the top gasket I believe, it was awhile back. I would recomended a pressure regulator
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 05-23-2010, 06:53 PM   #3
RichardJ
Re: Stuck float?
What problem do you have? If the float is stuck, down, it should be blowing black smoke out the tail. It will idle really rough at first, then die and wash the cylinder walls. Be sure and check for a leaking float as it will sink.
RichardJ is offline   Reply With Quote
Old 05-23-2010, 09:38 PM   #4
guardmp
Re: Stuck float?
It's not doing any of that. I just replaced the fuel pump, filter and lines from the tank. It cranks, but fails to turnover. I checked to ensure fuel was coming from the line through the filter and checks out ok. My only other thought is the float must be stuck....suggestions?
Old 05-24-2010, 02:10 AM   #5
Secret Squirrel
Secret Squirrel's Avatar
Re: Stuck float?
These videos helped me
http://www.edelbrock.com/automotive_...ech_vids.shtml
Secret Squirrel is offline   Reply With Quote
Old 05-24-2010, 02:40 AM   #6
guardmp
Re: Stuck float?
man those videos are awsome! They simply dumbed down the entire carborater trouble shooting process for "rocks" like me. Thanks; problem solved...
Old 05-24-2010, 02:44 AM   #7
Secret Squirrel
Re: Stuck float?
You are most welcome friend!
