Old 05-23-2010, 09:10 PM   #1
79widestep
79widestep's Avatar
sputtering?
ok i got a 93 blazer with a 4l60e from mad dog transmisson with a stage 2 shift kit this lil sputtering issue i just noticed the other day i was gettin on the highway so i floored it to get up to highway speed since people werent gettin over and right when the transmisson get ready to hit for the shift the it starts sputtering like its boggin down from to much gas so i back out of it and it goes away and runs normal just so it wasnt a fluke i did it again and the same thing happned but other wise the truck .. hmm i guess it not a truck i guess its a suv hmmm .. well any was it runs just fine except for that lil issue im not sure what it could be
truckin its not a hobby its a way of life
93 blazer
79 widestep
79widestep is offline   Reply With Quote
Old 05-23-2010, 10:36 PM   #2
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Re: sputtering?
Sounds like the inline fuel filter is clogged.
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 05-23-2010, 11:10 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: sputtering?
I had an issue once when the coil wire on my old Pontiac started breaking down under acceleration but worked fine otherwise. A set of plug wires and all was good.
Member Nr. 2770
Old 05-24-2010, 08:28 AM   #4
79widestep
79widestep's Avatar
Re: sputtering?
im gettin ready to change the spark plugs and wires this week end seeing i havent change them since i bought her lil over a year ago so maybe that will fix it
93 blazer
79 widestep
Old 05-25-2010, 12:09 AM   #5
Big J'72 GMC
Re: sputtering?
I'm having this same problem with my '96 Suburban. Changed the pulgs, wires, and fuel filter and its still acting up. Took it to my tranny guy who did a diagnostic an he said that its not my tranny he thinks it might be a computer problem. Gonna try putting in a piggy back system this weekend to see if that'll help. Any other ideas?
Big J'72 GMC is offline   Reply With Quote
Old 05-25-2010, 01:28 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: sputtering?
Is your Check Engine light on?
Can you get it read somewhere?
Member Nr. 2770
Old 05-26-2010, 08:24 AM   #7
ChevyTech
Re: sputtering?
It sound like both Widestep’s, and Big J’s trucks could have a restricted exhaust system.
And like ChevLoRay said, see if there are any trouble codes in the memory.
Old 05-26-2010, 08:32 AM   #8
79widestep
79widestep's Avatar
Re: sputtering?
nope i dont have any lights on indicating that somethinngs wrong and for exhuast im runnin glass pack which i dont like with the stock exhaust manafold
93 blazer
79 widestep
Old 05-26-2010, 10:00 AM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: sputtering?
When I bought my 1994 GMC 1/2 ton... it kinda did the same thing. Pulled the cap off of the distributor, and it was pretty messed up with carbon tracks, and all boogered up on the terminals. So... new cap and rotor, plugs, wires, and a new fuel filter. Made a big difference... but still did it once in awhile to a point it was gettin' a little annoying.
Then I installed an MSD coil... no sputtery no more.
http://www.summitracing.com/parts/MSD-8226/?rtype=10
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-26-2010, 10:23 AM   #10
JWall
Frequent Flyer
JWall's Avatar
Re: sputtering?
My 98 had a bad miss in it at cruising speeds a while back I did a tune up on it but I did the parts 1 @ a time so I could figure out what the problem was & mine was the plug wires.
Since everything on the truck was original when I got it for the tune up I did plugs, plug wires, dizzy cap, fuel filter, fuel pump (my guage wasnt reading correctly), & an engine temp sensor obviously after all that it runs like a champ now!
- Justin
1 Owner 1976 SWB
Old 05-26-2010, 11:31 AM   #11
ChevyTech
Re: sputtering?
It could have a trouble code stored without have the check engine light on.
You have glass packs, but is the catalytic converter removed or is it still there?
You could test the fuel pressure and make sure it is within spec.
I agree with the others that it could very easily be and ignition problem. Do consider the ignition coil because they do have their share of failures.
Old 05-26-2010, 08:50 PM   #12
79widestep
79widestep's Avatar
Re: sputtering?
there is no catalytic conveter i just checked and how much fuel pressure should i have and i tried to get it to bog down again today but it ran normal so maybe some trash in the gas i dunno much about the motor side of these trucks ...
and how much of a differnce does a MSD coil make.... is it a esy install never messed with one before
93 blazer
79 widestep
Old 05-26-2010, 09:09 PM   #13
ChevyTech
Re: sputtering?
Originally Posted by 79widestep View Post
…how much fuel pressure should i have ….
The TBI fuel pressure specification for small block Chevy’s is 9 – 13 PSI with the truck running.
C/K truck TBI systems do not have a fuel pressure test port, but the pressure must be tested with the engine running. The fuel pressure is tested by using fittings to “T” in a pressure gauge.
…and how much of a differnce does a MSD coil make.... is it a esy install never messed with one before
The only experience I have with them is removing them and putting stock equipment back on the vehicle.
Old 05-27-2010, 01:51 AM   #14
GASoline71
GASoline71's Avatar
Re: sputtering?
The one I installled in my truck was a direct bolt in replacement for the factory coil. I can post a pic of it if you want. I did mine in about 20 minutes. EZPZ... They have more windings in them and put out a higher spark.
Gary
Old 05-30-2010, 11:17 PM   #15
79widestep
79widestep's Avatar
Re: sputtering?
well guys i changed my plugs and wires today and it seems to be runnin better it hasnt bogged down any more excepts that few times but i noticed the gasket under the fuel injectors assyemble as blown out on one part of it i found some peices early this week but didnt know where it came from sorry crappy pics from cell phone this will be a easy fix but my question is will it cause any probs in the mean time till i get it fixed my dad said might act like a vacum leak im wondering what yall think
93 blazer
79 widestep
Old 05-30-2010, 11:27 PM   #16
Metal
Metal's Avatar
Re: sputtering?
I'm betting your just sucking in unfiltered air.....
"If at first you don't succeed use more duct tape" Red Green....
Danger --if you meet it promptly and without flinching -- you will reduce the danger by half. Never run away from anything. Never!
-Winston Churchill
A few of my holsters.............
Metal is offline   Reply With Quote
Old 05-30-2010, 11:56 PM   #17
bwood
bwood's Avatar
Re: sputtering?
You are possibly sucking some unfiltered air, but the leak is before the throttle blades/IAC so it really shouldn't act or give symptoms like a vacuum leak. Here is a link to Oreilly's for the part # on that gasket:
http://www.oreillyauto.com/site/c/de...&keyword=60038
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 05-31-2010, 11:28 AM   #18
79widestep
79widestep's Avatar
Re: sputtering?
ok thanks bwood and that does make sense about just unfilterd air thanks for all the helps guys
93 blazer
79 widestep
Old 05-31-2010, 03:07 PM   #19
GASoline71
GASoline71's Avatar
Re: sputtering?
Yep... the gaskets get old and brittle after years and years of sitting with gummed up crud on them. Pretty common, and will do as decribed above. No performance loss from it.
Gary
Old 05-31-2010, 10:06 PM   #20
Big J'72 GMC
Re: sputtering?
When my check engine light comes on it flags all four O2 sensors, not sur ewhat to make of this, never thought of a restricted exhaust
