05-23-2010, 11:18 PM | #1 |
Grease Monkey
Dana 60 Front Build
After a year of searching and waiting, I finally found a front Dana 60 when I could afford one. I picked this up today for $800. I have a huge list of parts that will probably take me a year to acquire.
The Parts List: Machine the DRW hubs to SRW Warn Premium Hubs #62672 Ballistic Fab D60 high steer kit (open to suggestions) 4.56 Gears ABR or Spool Powder Coated Chrome Diff Cover Cross Drill/Slotted Rotors Master Overhaul Kit
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
05-23-2010, 11:23 PM | #2 |
Boss Hogg
Re: Dana 60 Front Build
Nice!
If you plan on driving it on the street, go with the ARB. From what I have heard, Ballistic makes a good and inexpensive(compared to others) cross-over/high steer unit. |
05-23-2010, 11:33 PM | #3 |
Nice, and you ever get the cooling issue worked out?
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
05-24-2010, 10:05 AM | #4 |
I would make sure the steering arms you buy eliminate the KinPin Spring. That pesky spring alows for "death wobble" to happen. Not everyone gets death wobble but with the spring eliminated you won't have to worry about it.
Congrats!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
05-24-2010, 03:28 PM | #5 |
Grease Monkey
Thanks Burt. Good to know. The ballistic fab arms do eliminate the spring.
05-24-2010, 10:34 PM | #6 |
Grease Monkey
Today I tore down both knuckles. The kingpins look bad to me. Let me know what you think.
05-24-2010, 11:25 PM | #7 |
Currently Blazerless
They look scored to me...what did the poly bushings look like?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 05-24-2010 at 11:27 PM. |
05-25-2010, 12:09 AM | #8 |
800 bucks for a drw dana 60. wow!
05-25-2010, 09:37 PM | #9 |
Grease Monkey
Nother SCORE!!! Picked up slightly used SRW Hubs, used knuckles, new kingpins, new dual calipers set, and other misc. items for the dana 60 for... only $160. Gotta love craigslist. Its funny cause i know the guy through another wheeling buddy of mine. He also has a set of brand new in the box warn premium hubs that he is including in the deal once he finds them. Now I just need gears and a locker, anyone?
05-25-2010, 10:40 PM | #10 |
6>8 Plugless........
Nice score!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-26-2010, 12:15 AM | #11 |
Grease Monkey
Is older chevy and ford bolt patterns the same?
05-26-2010, 12:38 AM | #12 |
SWB 4x4 Collector
Make sure the d60 sw hubs are for lockout hubs. I hear they are different. Something to do with a guide in them or something I think. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-26-2010, 12:34 PM | #13 |
Yes they are, but I believe the ford hub center is larger. But shouldn't matter a lot.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 05-26-2010 at 12:36 PM. |
05-26-2010, 10:34 PM | #14 |
Grease Monkey
Ok did some more research and found out that the parts are bought were Ford. Now I have two options. One, use the parts I bought and find ford outer shafts. Two, keep searching for chevy hubs. The only reason I might use the ford parts is I have a dual piston caliper for better braking power and I might have all the parts needed. Still waiting to her back from my buddy to see if he has ford axles laying around. Need some input...what do you think.
05-26-2010, 10:40 PM | #15 |
SWB 4x4 Collector
I'd keep searching for GM stuff. Ford stuff would make you change transfer cases I believe. I think all of the ford stuff was driver drop. Trevor
05-27-2010, 06:24 PM | #16 |
Grease Monkey
Only the knuckles out are ford. The housing and stuff are Chevy
05-27-2010, 10:53 PM | #17 |
The ford stuff will work fine just get a set of shafts. then you can sell the chevy knuckles for a little more $ because they are the ones all the crawlers want.
1949 Five Window, 1973 Step Side, 2000 Z71 |
05-28-2010, 08:54 AM | #18 | |
I never bothered to check so maybe the OEM brake brakets can be used. Or machine the DRW hubs to SRW, I that to but i did most of the hard work before they went to the machine shop. I plasma cut the major parts off then I ground most of the high spots down. That way I would be charged less to have them skim cut them on the lathe to 4 5/8". I dont have them back from the machine shop but heres a fuzzy pic of what they looked like prior to going there. I will plamsa cut some plates that will fit over the hub body and then gets welded to the ears. That will be plenty for what I want to do. Jason. |
05-28-2010, 08:40 PM | #19 |
Grease Monkey
The only reason I didn't machine my DRW hubs down is because they are in excellent condition. I was told to try and sell them. Originally that is what I planned on doing.
05-29-2010, 05:36 PM | #20 |
Strongman Garage
You can get brand new SRW hubs from www.gmpartsdirect.com for real cheap. I can find the part # if you want
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
05-29-2010, 10:41 PM | #21 | |
Grease Monkey
So here is what I accomplished today.... Finished cleaning and painting everything today. I am awaiting my hubs via us mail. I still need to order my hi-steer arms and locking hubs.
06-07-2010, 11:14 PM | #22 |
Grease Monkey
I ordered Ballistic steering arms and the new hubs and rotor assemblies are on there way.
06-08-2010, 10:01 AM | #23 |
looks good! that sucker is burley!
1970 k20 350 4speed hd44 14b Circumventing the language filter is against site rules |
06-09-2010, 01:20 AM | #24 |
wow! is that the going price for a chevy 60 out there? i bought TWO whole m1008 chevys for that, and they already had 4.56 gears. drove one of them home.
06-09-2010, 11:58 PM | #25 |
Grease Monkey
yeah, well things are twice as expensive on the west coast. I can find Dana 60s all day long for $500 or less on the east coast.
