Old 05-23-2010, 11:40 PM   #1
ranger2339
ranger2339's Avatar
Front Disk brake conversion on my 70 C20?
Can somebody please educate me on what I need to convert my front brakes to disk, on my 70 C20? All the threads I searched were 1/2 tons , so I just wanted to double check with the board and see if I have this correct?
From what I have read I can just use the disk set up from a 73-88 3/4 ton? Anything special I need?
Thanks,
Josh
ranger2339 is offline   Reply With Quote
Old 05-24-2010, 07:57 AM   #2
Beuford
Beuford's Avatar
Re: Front Disk brake conversion on my 70 C20?
I just did this to mine. If your using `72 spindles you'll need upper and lower ball joints for a `72 and the center steering link wit `72 outer tie rods. If you don't have the center link you can buy an adjustment sleeve that has both diameters on it as the outer tie rod ends on the `72 are bigger than the stock `70 outer threads. You'll need a mastercylinder and a proportioning valve for disc brakes. My C 20 had a long rod in the booster and I had to shorten it to work wit the disc brake master cyl. My booster is the small one and new so a machine shop cut the rod shorter and re threaded for the adj screw in the end of the rod. There are alot of guys on here that can probably explain it better. Good Luck.
Beuford is offline   Reply With Quote
Old 05-25-2010, 04:39 PM   #3
ranger2339
ranger2339's Avatar
So Can I just swap the whole subframe from a 72-87?
Thanks,
Josh
Old 05-25-2010, 04:47 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, 71-87 parts are a straight swap. Everything you have researched about 1/2 tons is the same as 3/4 ton, just heavier parts and more wheel lugs.
Either do the arm/ spindle swap or the entire side-to-side swap as you see fit using a 3/4 ton donor.
Old 05-25-2010, 04:50 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
yes, you can swap the whole subframe. get everything from the front end steering wise that you can to make the swap easier....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-25-2010, 04:55 PM   #6
ranger2339
ranger2339's Avatar
Awesome thanks a ton guys. Ill prob. just buy a complete truck and swap over what I can, my steering components are in poor shape anyway.
My truck is 2wd, can I use a 4x4 truck for a doner, and just 86 the 4x4 stuff?
Thanks,
Josh
