Old 05-24-2010, 12:39 AM   #1
jmking9
jmking9's Avatar
Question about fuel fitting
Im going to run braided fuel line from the stock tank to the carb. My question is does anyone know what fitting is required at the tank right out of the sending unit? Ive tried a 3/8 NPT to AN fitting and it doesnt fit. I dont have too much experience with this kind of thing, so any input is appreciated.
I borrowed this pic from a board member (hope he doesnt mind) to show where Im talking about.
Also should I use -6 or -8 An for the line?
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 05-24-2010, 07:14 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Question about fuel fitting
-6 should be fine as long as you do not have a crazy killer motor
I urge your caution running all braided line for your fuel - the liner is permiable and will soften over time allow fuel fumes to escape.
This is hastened if you us bad fuel
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 05-24-2010, 07:40 AM   #3
custom70
custom70's Avatar
x2, why not just connect it under the cab instead. Then you won't have a smell problem in the cab later.
custom70 is offline   Reply With Quote
Old 05-24-2010, 10:21 AM   #4
jmking9
jmking9's Avatar
Is the hard line that comes out of the cab 3/8 tube? If so, do you think this fitting from summit will work.
http://www.summitracing.com/parts/RUS-639210/
1970 SWB Build
Old 05-24-2010, 01:56 PM   #5
custom70
custom70's Avatar
If the line is 3/8 I think that might work. Although it does mention it is for aluminium line? Don't know how it will work on steel line?
Old 05-24-2010, 02:40 PM   #6
71tahoe
71tahoe's Avatar
Speedway may have a better selection. The tube is an inverted flare fitting (IFF) and they should have an IFF to AN adapter.
71tahoe is offline   Reply With Quote
