05-24-2010, 01:02 AM | #1 |
C60 truck 292 valve lash specs
I scored an actual "truck" motor and put it in my son's 65 C20. The motor is a 1966 and I believe it has solid lifters. I guessed and set the valves at .015 and it runs fine with some clicking. I cannot tighten the rockers any tighter than zero lash while running, it never recovers like a hyd motor would, it just misses. My question is this; was my guess right, or even close? What is the spec supposed to be on setting the valve lash for this motor?
"..not ashamed of the gospel" Rom. 1:16 1968 C10 (newly acquired) 1967 Checker Marathon (waiting for paint) 1968 C50 Service Truck (resting in peace for now) I need another project like I need another hole in my head!!! |
05-24-2010, 05:51 AM | #2 |
Re: C60 truck 292 valve lash specs
i believe it should b .005 intake .015exhaust from what i see solid lifters in an older book i have
05-24-2010, 11:01 AM | #3 |
Old Duffer
I'm suspicious of solid lifters in a '66 292. I understand what you're saying about the stumble when you go to "0" lash, but I think I'd pull the forward side cover and visually confirm the lifter type.
JMHO
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
05-24-2010, 06:42 PM | #4 |
All 292's had hyd. lifters. It should have them unless someone has changed them over which is highly unlikely. They probably needed adjustment for a long time & are stuck in the top position. Maybe an additive in the oil & turn them down one at a time & see if it will stop missing after a minute or so. I would pull a cover like the guys said & take a look at them.
05-25-2010, 12:05 AM | #5 |
yeah, this thing sat in the warehouse for eight years. Turns over freely, I surely wouldn't think the lifters would freeze before the cylinders. I got lotsa books and couldn't ever find a spec on 292 solids. I'm gonna pull the side cover and look. If they are solids, somebody other than Chevrolet did it.
Thanks for all the responses.
