Old 05-24-2010, 02:34 AM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
raise bed floor
anyone got pic or info on how i could do this
reason for this is cause i have a big c-notch
any info would be great!
oh and im trying to keep the wood bed look
Sick5 is offline   Reply With Quote
Old 05-24-2010, 04:00 AM   #2
The_BullDog
The_BullDog's Avatar
Re: raise bed floor
http://67-72chevytrucks.com/vboard/s...d.php?t=324997
great build to check out.
The_BullDog is offline   Reply With Quote
Old 05-24-2010, 09:43 AM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: raise bed floor
looking for more 60 year but yah that is a bad truck
Old 05-24-2010, 09:47 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: raise bed floor
here is what I would do:
the cross sills that support the bed and the wood floor attatch to the sides of the bed. the sides form a "L" at the bottom to bolt all this together.
what I would do is leave the original cross sill attached, except where they interfere with the notch.
then I would take some 1X1 angle iron and weld, or bolt it around the perimeter of the bed and front bed panel.
attach it so that the bottom of your wood floor will clear the notch.
I would also put them on upside down from the way the factory "L" looks. -so the wood will rest on top of your new angle instead of under it.
next I would replicate the cross sills with some 2X2, or 2X3 tubing and mount the new cross sills at the higher level right above the old ones. You should probably run some extra tubing between the old and new cross sills to strengthen things up.
then I would buy a bed wood kit, and bolt kit and bolt it all up.
at the back of the bed you will have to deal with the rear sill, I would get a piece of metal that is shaped like a "c" (so you can access all the bolts from under the bed)that is the same hieght as the step difference, would probably put a couple braces inside that for strength as well.
Old 05-24-2010, 11:47 AM   #5
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: raise bed floor
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=301368
http://67-72chevytrucks.com/vboard/s...d.php?t=381425
jonzcustomshop idea doesn't sound to bad.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 05-24-2010, 08:53 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i had the same idea but never thought about leaving the sill intack i was thinking of using them
i have a few bed rails i was going to use as my "L" for the front of the bed and the rear
and i was thinking of cutting the bottom of the bed side and just raise it and weld
no one has anykind o tut? would be nice to have something i can follow!
i need to find a scrap yard and by some 1x1
Originally Posted by 1Bad62Pro/Street View Post
i love the first web link of the grey and black 66 looks good that aluminum bed was great
Old 05-25-2010, 09:41 PM   #7
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: raise bed floor
anyone got any pictures of a reg bed
