Old 05-24-2010, 10:30 AM   #1
ACII
How to use a car lift with a rear axle air ride ??
Hello,
i am just wondering how to use a car lift with an rear air ride suspension..
I think it is not really good for the bags if the rear axle is hanging free, just hold in place through the bags !!!????
Let me know ur tricks to get the truck up with a car lift ?ß
Thx
achim
ACII is offline   Reply With Quote
Old 05-24-2010, 10:40 AM   #2
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Re: How to use a car lift with a rear axle air ride ??
Some brand of bags have no problem just hanging and holding the weight of the axle. But what I have always done. Get a ratchet strap. And strap around your axle and frame or notch crossmember. Usually one on either side works fine.
AVS_JASON is offline   Reply With Quote
Old 05-24-2010, 10:55 AM   #3
Tony@AirRideTech
Junior Member
The shocks should catch the bag before it over extends if everything was installed right. If the shocks dont catch it you can install some limiting straps.
Tony@AirRideTech is offline   Reply With Quote
Old 05-24-2010, 10:59 AM   #4
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
True, shocks should limit your axle too.
Old 05-24-2010, 12:27 PM   #5
LEEVON
Moderator
LEEVON's Avatar
The method isn't the part I have a hard time with, it's explaining it to the oil change boy at the dealership I just go to a place where the put it on the rack instead after a bad experience with a lying service manager.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-24-2010, 01:14 PM   #6
ACII
off course the shocks ....i forgot them .....alright thanks for the advice ..
i fix them into the right position
thx
Achim
