02-13-2003, 02:03 PM | #1 |
Alternator
My alternator and or voltage regulator is out on my '72 suburban. Should I replace it with a newer one-wire alternator with internal voltage regulator or go back with the original style? What are the pros and cons?
02-13-2003, 02:11 PM | #2 |
Half a bubble off!
Go to the internally regulated alternator, it's an easy and worthwhile upgrade. I have the kit available to make this a very easy change, PM me if you are interested and I will give you the details.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
02-13-2003, 03:13 PM | #3 |
I just did this two days ago. I would go with the one wire alternator, you won't believe the difference this makes. I bought my alternator from scoggin dickey's, I got the 140 amp, 1 wire alternator. It is easy, at first I had some problems, but once I got it wired in and seen, how it works, every thing is cut and dry. PM me if you want more details.
Sam
72 LWB chevy truck. Pasadena, Texas |
02-13-2003, 05:55 PM | #4 |
Half a bubble off!
Sam, I didn't know you used a 140 amp alt., why? Standard delco alt. is all you need.
02-13-2003, 07:03 PM | #5 |
Larry,
I went on ahead and went with the 140, wasn't that much more, and later on I am planning on putting a good sterio system in it, and felt like it would be good to go with the 140. I pmed you about how I wired it up. It is the same way that piston, ( member of board ) does his, he has a drawing out that shows just how to do it. Sam
02-13-2003, 09:12 PM | #6 |
Could someone post this information as a article for everyone to see........
I'm currently still running the old style, and after reading posts on the subject was considering changing it over along with an HEI distributor.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
