Old 05-24-2010, 11:05 AM   #1
wldcat10
wldcat10's Avatar
How to install Grille on 1970?
Can anybody help me out on how to install a Grille on a 1970? Do I have to take off the bumper? Any help will be appreciated, thanks!
1970 CST/10 LWB 350
1984 Blazer
wldcat10 is offline   Reply With Quote
Old 05-24-2010, 11:14 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: How to install Grille on 1970?
Yes, in order to properly install the grille and without damaging it, you must remove the front bumper. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-24-2010, 11:16 AM   #3
71blksuper4x4
SWB 4x4 Collector
Make sure to remove all of the bolts up in the top sides of the grille between it and the radiator support. You will think you have them all, but sometimes you forget one or two that are back in there. I think there are 3 or 4 up in the tops, and 2-3 at the bottom sides. Unplug the front turn signal lights and that should be all to take it off. Trevor
TREVOR
Old 05-24-2010, 11:35 AM   #4
wldcat10
wldcat10's Avatar
Ok the thing is, I don't have a grille on it at all right now. Is there any how-to- instructions on how to install a '70 grille?
1970 CST/10 LWB 350
1984 Blazer
Old 05-24-2010, 12:46 PM   #5
tim21391
tim21391's Avatar
it mounts to the side of the fenders and at top by the hood latch
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-24-2010, 02:18 PM   #6
DorianB
DorianB's Avatar
I can help with a little bit if it is the same as my '68.
You should have one middle support bracket that attaches to the grille and the Chevy logo emblem in the front. This center brace also helps support the hood latch. The hood latch will span from in front of the radiator to the bottom support bar and to the front of the grille. (5 screws hold this on if I remember correctly)
There at least two screws at the top that screw into the sides. (Bolt and washer for all of these btw.) I didn't take mine completely off, but that is coming in the near future.
DorianB is offline   Reply With Quote
Old 05-24-2010, 03:02 PM   #7
wldcat10
wldcat10's Avatar
I think the '68 may be a little different to install then a '70, but I may be wrong? I do have the middle support hatch though.
I'm really just in need of where to bolt the grill onto? Anybody got any pics of instructions how to do it?
1970 CST/10 LWB 350
1984 Blazer
Old 05-24-2010, 03:10 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
It bolts to the insides of the fenders and to the hood latch. If you bought a new grill you'll need the grill mounts as well that have to be pop riveted to the grill itself.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-24-2010, 03:35 PM   #9
john
member #16
john's Avatar
The brackets sinister is referring to are #'s 5 and 6 in pic.
john is offline   Reply With Quote
Old 05-24-2010, 03:47 PM   #10
wldcat10
wldcat10's Avatar
Well I bought the grille, so it is new to me! But I think I have those grill mounts on it. I need to check when I get home.So all I would need is to bolt on the two sides onto the fenders and just up top on the hood latch?
1970 CST/10 LWB 350
1984 Blazer
