Old 05-24-2010, 11:17 AM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Bed clearance
I don't have a bed right now (the one that was on the truck when I got it wasn't worth trying to restore so I scrapped it a while back.)
I have the major components hung now and am doing all of the adjusting and checking before ratcheting everything down. I have already discovered that I will need to make some clearance room in the shock c.member to clear a reienforcing web on the top of the rear end and it seems to me that the top of the rear end will etend a fair amout above the frame when it is aired out.
How much (if any) clearance is there between the frame and the bed floor in this area?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-24-2010, 12:07 PM   #2
panhandler62
Java Mechanic
Re: Bed clearance
Here are some pictures.... lots of tweaking to do here still too... think I'll need to move the track bar mount cause the bar doesn't reach.. lol
Keith
Old 05-24-2010, 06:28 PM   #3
SCOTI
SCOTI's Avatar
Re: Bed clearance
Do you plan on running bump-stops? If so, the rear will prob touch the bed floor @ the same time the bump-stops hit using standard height stops. If you opt for the very short/pancake style stops, you'll hit if you don't make clearance. The pumpkin can protrude about an inch above the floor.
You could always cut a hole for clearance & install a shallow 'cover'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-24-2010, 08:14 PM   #4
panhandler62
Java Mechanic
Re: Bed clearance
I do need to add some bump-stops here.
I plan on running a wood bed. I haven't seen wood beds with modded floors but I guess I can figure something out if it comes to that.
I rolled a tire up from the shed to see where I was at. I think it's going to end up just about where I wanted it.
Keith
Old 05-24-2010, 11:18 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Bed clearance
If your going to have to build a bed from pieces, I would just raise the entire bed floor. It won't be as deep, but better than a hump in my mind.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-25-2010, 07:49 AM   #6
panhandler62
Java Mechanic
Re: Bed clearance
It's a good point... I have no plans to haul things (well, nothing big and heavy anyway) in any case, so it won't hurt to raise the floor a few inches.
Keith
Old 05-25-2010, 08:03 AM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Bed clearance
hey Keith I think your going to be very close you have the same set up I have..if you put something across the frame as long as the top of the pumpkin is less than 1 1/2" above the frame your good...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
