LS swap quick questions on motor mounts
I have a 70 C10 that I am going to be putting a Gen III 4.8 with the 4l60 out of a 2000 GMC truck. I want to use the stock manifolds as well. I have been looking at the Trans Adapt 4572 and the 4575 motor mount adapters.
1. Should I get the motor mount adapters for stock location or the ones that push the engine back 1"? 2. If I decide to use a F-body oil pan for more ground clearance, which motor mounts should I use? 3. Are these plates big enough that if I need to move the engine forward or back a little, I will be able to drill out new holes? Thanks Mickey |
Right on the line, baby!
Re: LS swap quick questions on motor mounts
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I really dont think you will be able to run stock manifolds unless the ECE motor perches/mounts will allow it. I have used the CPP tubular and the POL tubular mounts, the CPP's wouldn't work for me ( put the motor forward), I used the POL, it puts the motor up and to the rear, allowing for dual fan placement.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Digging up an old thread....
I noticed your from Bako, ever get your swap done? Take care!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
Truck pan will not work with ece
Posted via Mobile Device |
Ece and Ctsv pan fits great this is what I'm using almost a half inch above crossmember got this idea from another member.
