Old 05-24-2010, 10:41 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Do I need drop shocks with jeep springs?
Do I need drop shocks with jeep springs (rear)? And Should I buy the fronts too? Will they lower the front or anything or am I better off chopping my current front springs?
What are a set of 4 worth? 97 tj jeep springs
John
1999 Toyota Tacoma 4x4
Old 05-25-2010, 05:14 PM   #2
67Slider
67Slider's Avatar
Re: Do I need drop shocks with jeep springs?
Curios about the drop shocks too. Just installed the jeep springs and the shocks don't bottom out. But thats just from me jumping up and down on the back and grinning like the Chesshire Cat that I finally got the darn things put in..........
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 05-25-2010, 05:29 PM   #3
Leviticus
Shake and Bake!
Leviticus's Avatar
I am not sure on what the total drop you get with the TJ springs is, but I have heard around 3-4". I would slap some new ones in if going over 3", but if they don't bottom out on you, then I would just roll with them and get shorter ones when they need replacing.
And as far as the front TJ springs I don't think they will be any use to you on old blue. If you want some cheap front drop just pull your coils and cut 1/2 to 1 full coil off and put them back in.
Post some pics when you get them in. And don't forget to center your rear axle after the drop
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-25-2010, 05:59 PM   #4
oldblue1968chevy
Well I just got back. Picked a set of 4 springs up for $30.00.
I have new factory replacement style shocks. I'll do a lil write up about em later.
Center my rearend..HUH lol?
John
Old 05-25-2010, 09:42 PM   #5
oldblue1968chevy
Still need to know about 'centering' my axle
anyhow here are a few pics
sorry about the dark pic, it was dark when I went inside..will have better pics tomorow
dad thinks im nuts wanting to go lower with a skinny spring, he says soon as i have the bed on my axle and frame will be sitting on each other
bumpstops dad, bumpstops
John
Old 05-26-2010, 09:40 AM   #6
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I'm curious to see how this pans out. I cant tell you how many sets of TJ springs we have thrown out at the shop after installing lift kits!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 05-26-2010, 11:10 AM   #7
oldblue1968chevy
So far so good
pick up some new bolts before you start
one of my spring cup things cracked, i welded it back up
still unsure if I need an adj. panhard bar/drop shocks..
do I have to center the axle? is there that much of a difference? Im about to have the other side done ill post pics when its thru?
may make an adj. panhard bar ive gota spare now
John
Old 05-26-2010, 11:33 AM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
At the very least you will have to use an adjustible panhard bar and if the drop is 4" or more likely a super bar kit. Is it necessary? I would say so, if you want your truck to handle right. Looking at the diameter of the Jeep springs, it looks like you will have a bit more suspention travel, do to how light they are. That will only make the handling carictoristics worse with a stock panhard bar in the stock locations. You should install a shock relocating kit also, witch will help the springyness (spell) that is likely to happen while driving down the road. I have installed 3 super bar kits (including one in my shop now) in as many months here for customers who thought they didn't need one and found out otherwise. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-26-2010, 12:02 PM   #9
oldblue1968chevy
Ok thanks!
Got it all together and drove it a mile or so...
Came back measured again
Thanks for the info wes! i'll check you out shortly
John
Old 05-26-2010, 12:03 PM   #10
oldblue1968chevy
Im guessing without the bed on I dropped about 3"
John
Old 05-26-2010, 01:37 PM   #11
Classic Heartbeat
Whats the panhard bar look like now? Is there mutch angle on it?
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-26-2010, 01:42 PM   #12
Classic Heartbeat
Here is a shot of the one we just installed under the 70 CST in my shop. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-26-2010, 01:48 PM   #13
Classic Heartbeat
Notice the angle of the panhard bar and the shocks both. The flatter the trajectory the less effective they are. When you lower you flatten both. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-26-2010, 02:44 PM   #14
oldblue1968chevy
the shocks are laid down more than they were with stock springs
any measurements I should take? thanks! i'll try to get a a pic soon
John
Old 05-26-2010, 04:54 PM   #15
Classic Heartbeat
If your shocks are laid down, then a shock relocation kit is in order, and also 4" lowering shocks. The only measurements that I take are the rear end back plate to frame measurement. They should be the same on each side to be sure your rear end is centered. The angle of the shocks should be as close to 15 degrees and the same with the panhard bar. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-26-2010, 07:20 PM   #16
budgetstperformance
budgetstperformance's Avatar
Ok thanks!
hey old blue did you take a measurment from side to side? did it put the axle to one side? i wasn't worryed about it till you asked me.
budgetstperformance is offline   Reply With Quote
Old 05-26-2010, 07:25 PM   #17
oldblue1968chevy
I measured earlier from a part of the frame to the start of the tread on the tire, it was maybe 1\2" or less difference, IF that..I may do some homade stuff (adj. panhard) and play with the shock brackets
John
Old 05-26-2010, 07:50 PM   #18
budgetstperformance
i just ordered one of these from brothers truck $70 + shipping
track arm
old blue you can count on that measurment changing once the bed is in place.
Old 05-26-2010, 08:59 PM   #19
Classic Heartbeat
Those track arms are ok for drops less than 4". Any more than that I would run a super bar kit. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-26-2010, 11:18 PM   #20
oldblue1968chevy
Well,hopefully tomorow or so I get my bed notched for my gas tank
what is it hurting to run without one? thanks
John
