![]() Join Date: May 2010
Gear Ratio?
How do I find out what gear ratio came in my truck?
Re: Gear Ratio?
do you wanna now the original gear that shuod have its kind of hard unless it haves the original drive train check out glove box if its the ori.
cucharitas customs |
Active Member
![]() Join Date: Oct 2002
Re: Gear Ratio?
Drain it, remove the rear cover, look on the ring gear find the stamped code,
one set of numbers are a date code, the others or the numbers of teeth on the ring gear and the number on the pinion, divide the two and you have it. |
#4 | |
Re: Gear Ratio?
it will be an hour well spent
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-25-2010 at 06:53 AM. |
Re: Gear Ratio?
There's a best way, and there's an almost as good way without having to get greasy.
Put matching marks on the pinion yoke and differential housing. Jack one rear wheel off the ground, put the transmission in neutral, and the parking brake off. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio. If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear. Ray |
its all about the +6 inches
Re: Gear Ratio?
the gear oil is probably 20 to 40 years old, and only working at 50 to 75% what it was when filled. So a drain and fill is a good idea for any reason.
However, the initial question was asking what was there originally, not what is there now. What year, what size truck (10, 20, 30) what engine and what tranny was original... all this assuming nothing was listed on the SPID for optonal gears |
Re: Gear Ratio?
yeah y like the last one but y always have problem that way sometimes the tire spins not equilie
Re: Gear Ratio?
Thanks for the help.
"Hooked on Quack"
Re: Gear Ratio?
I prefer the drain and look method if the truck is new to you that way you can get some new fluid in there anyway and find out.
Semper Fi, Kevin ![]() ![]() |
