05-25-2010, 10:08 AM | #1 |
"Hooked on Quack"
Military Tires
OK got a quick question. Around here there are a million sets of military tires for sale. They mainly come in 2 flavors the 36x12.5 goodyears and the 37x12.5 goodyears. I have run the 36's before and while they are a hard tire and will last forever I am just not a huge fan of them. So I have been pricing several different tires.
Throw in this monkey wrench I found a set of old style aluminum slots in 8 lug which I really like issue being they are 16.5 and tires go for around $400 bucks each, while I can get the 37x12.5 military M/T's for about $300 a set. My question is how well do the 37" version do on the road as far as handling and ride etc. Just trying to get some opinions on that version as I have never run them
Semper Fi, Kevin USMC |
05-25-2010, 11:30 AM | #2 |
SWB 4x4 Collector
Re: Military Tires
I used to run those on my old 72'. They are fine. A lot smoother riding than the 36"s. (I ran those as well) They do tend to wear down much like the 36"s, but for $300/ set, you can't go wrong if setup for them. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-25-2010, 03:50 PM | #3 | |
"Hooked on Quack"
Re: Military Tires
My truck right (just bought 2 months ago) actually has the 36's on them, gonna get my new rims and a set of 37's then sell the 36's. so I should come out almost even. on tires but go up in size.
05-25-2010, 09:27 PM | #4 |
Re: Military Tires
I've been thinking about going to the radials as well. Not super happy with the driveability of the Bias tires. How much taller are they? I can go up a little in height with my 4" lift, but not a lot. The 36's are almost identical in loaded height to my 35" BFG MT's that came off.
05-26-2010, 10:02 AM | #5 |
"Hooked on Quack"
Re: Military Tires
There are 2 sizes in the military pull-offs that I was referring to the 36x12.5 and 37x12.5 both are on 16.5 rims. Now there are ton more sizes of pull-offs but these are the HUMVEE pulloffs not the big trucks heck you can get 52" military tires.
05-26-2010, 10:37 AM | #6 |
SWB 4x4 Collector
Re: Military Tires
Pretty sure when my set of the 37"s were new, they measured almost a true 38". Once they wear though, yes the right at 37"s. It's been several years since I ran them, but I ran them until I lifted it higher for 42"s. I'll dig for a pic of them on it. Trevor
05-26-2010, 09:49 PM | #7 |
Re: Military Tires
Sorry if I was unclear, I thought it was obvious we were talking 36 & 37 Humvee tires.
The loaded height of my 36's is the same as my 35" BFGs, right at 34". By loaded I mean mounted on the vehicle with 22 lbs of air measured from the ground to a level across the top of the tire. I would figure the Michelin radials would be about 35"-36" loaded measured the same way.
05-27-2010, 10:03 PM | #8 |
"Hooked on Quack"
Re: Military Tires
Which Michelin radials? I haven't seen those the 37's I have seen were Goodyear m/t's.
05-27-2010, 10:18 PM | #9 |
Re: Military Tires
How cool is it that this topic came up? My old dry-rotted 31x10.5 tires that came on my 79 Burb are giving up the ghost. And I'm seriously thinking about going with the HMMWV 37s.
My questions are, what is the recommended lift for tires this tall? And also on some other board they were bashing these tires, saying their pavement handling characteristics were horrible. Now I've driven HMMWVs and other military types on and off road but never noticed anything negative. Anyone that has driven on them, have anything bad to say about them? Thanks
SEMPER FORTIS U.S. NAVY 97-05 USAF 94-97 |
05-27-2010, 10:43 PM | #10 |
Re: Military Tires
I've had 37"s on a HMMWV and driven on the autobahn and they are a lot better than the 36"s.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
05-28-2010, 08:16 AM | #11 |
Re: Military Tires
I think that you will need a 6" lift minimum, and larger if you plan to bounce it around hard on the trail, depends on the truck though. You could also trim some metal if you had rubbing...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-28-2010, 09:20 AM | #12 |
6>8 Plugless........
Re: Military Tires
I've ran bothe sets of the goodyears and I like the 37's a lot better. It has a lot to do with them being a radial vs. a bias ply. The only problem is around here the 37's aren't as plentiful for some reason.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-31-2010, 08:01 PM | #13 |
Re: Military Tires
They are available lots of different places on line. I got a quote for 5 of the Michelins delivered from California to Texas for $580. His tires are 90% tread used. I paid $550 delivered for 5 36" Goodyears brand new which is what I am running now. Don't care for the biasply ties.
Anybody with loaded height measurement on the 37's?
06-01-2010, 11:16 AM | #14 |
"Hooked on Quack"
Re: Military Tires
well these are gonna have to be my second set of tires, I ran across some 37" Super Swamper SSR's on rims for $300 so I picked them up. I like that the new rims are 16.5 so as soon as the SSR's are gone I will go the the 37"
My question would be the same as Mike C can anyone tell me how tall the 37's are once on the vehicle because the SSR's fit but I am thinking of adding a 4" lift to my truck so they have more room they look a little "stuffed" but if the HMVEE 37's are much shorter I may save the money and deal with it.
06-01-2010, 11:12 PM | #15 |
SWB 4x4 Collector
Re: Military Tires
If the 37"s are close to being new or new... they measure almost 38" tall. If they are 1/2 tread or so, they are more in the 37" range. Trevor
06-02-2010, 10:08 AM | #16 |
"Hooked on Quack"
Re: Military Tires
cool I will be adding the additional 4" for sure...............but then I am gonna want to run some 39's
10-06-2010, 09:48 PM | #17 |
Re: Military Tires
Does anybody know where to get 6 lug 16.5 wheels to run the humvee tires on a half ton? I don't want to upgrade to 3/4 ton axles because my factory axles are 4.11 posi and i've seen half ton axles with much bigger tires go through hell and not break (I don't plan on beating my 71). I have a new set of the 37 radials I picked up for $300.
10-06-2010, 10:07 PM | #18 |
Re: Military Tires
my 87 is on the 37x12.50s and they ride REALLY good for big tires. ive had all kinds of tires over 35 inches and personally they are my favorite. they ride the best. they clean out the best. and they are cheap. if our military has used them for years and we all know they beat the living $#it out of stuff with no problems. they are top dog in my opinion. just my $.02
current trucks= -DD 90 RCSB 4x4 350/700r4 (green goblin) -87 RCSB 4x4 on 3/4 tons. 355/built 700r4.np208(soon to be 205). 10 bolt front 3.73s. 14ff rear 3.73s. 6inch suspension 3inch body. 37x12.50 Wrangler m/t military's. (sinister 13) Past 73-87s= -81 RCSB 4x4 built 350/SM465/205. 6inch suspension. 35x12.50 courser a/t's. 4.11s f/r (ravvid red) -80 RCLB 4x4 454/350/205. 6inch suspension 3inch body. 38.5 gumbos. (mudslut) 17 years old. have had 13 different vehicles. no wrecks. Last edited by 81k10; 10-06-2010 at 10:08 PM. |
10-07-2010, 09:04 AM | #19 |
Re: Military Tires
I would always go with the 37's in stead of the 36's. They are just made better IMO.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
10-07-2010, 03:43 PM | #20 |
Re: Military Tires
That's because the 36's are bias ply and the 37's are radials. Night and day difference.
