Old 05-25-2010, 12:28 PM   #1
tim21391
tim21391's Avatar
fuel pick up
how do you take the fuel pickup outta the tank
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-25-2010, 12:39 PM   #2
lovnthe70
lovnthe70's Avatar
Re: fuel pick up
Your asking about the sending unit and float??? There is a lock ring that you turn counter clockwise, hit it with a flathead and a hammer. That retaining ring will pop out.
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 05-25-2010, 12:40 PM   #3
sgaylord
Project collector
sgaylord's Avatar
Re: fuel pick up
There is a ring that is around the sender body. Use a brass punch or something that will NOT produce a spark and tap the ring away from the stops. Then remove it all as an assembly.
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 05-25-2010, 12:46 PM   #4
tim21391
tim21391's Avatar
Re: fuel pick up
does it matter if i have a half tank gas still in?
Old 05-25-2010, 12:46 PM   #5
tim21391
tim21391's Avatar
Re: fuel pick up
just tryin to see if its plugged
Old 05-25-2010, 12:51 PM   #6
lovnthe70
lovnthe70's Avatar
Re: fuel pick up
no you can still take the sending unit and float out, if you plan on pulling the whole tank out its easier if its not so full but can still be done.
heres a pic of the ring you need to turn, i just use a flathead screwdriver.
1970 GMC- 454
Old 05-25-2010, 01:59 PM   #7
cdowns
cdowns's Avatar
Re: fuel pick up
there's an oring in there that seals it// good idea to replace it when reinstalling sender
Old 05-25-2010, 02:12 PM   #8
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: fuel pick up
They also sell a special tool to remove the ring; it becomes very useful when you want to retighten the sending unit lock ring.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
